Brake Pads
Old Feb 3, 2012 | 02:59 PM
GeoffreyM's Avatar
GeoffreyM
Brake Pads
Anyone change em yet? My warning light went off today and the dealer is 100 miles away. I figure I can do them myself.
Old Feb 4, 2012 | 06:35 AM
THE ITCH's Avatar
THE ITCH
Your brakes are part of the free maintenance program if you are still within that period.
Steve
Old Feb 4, 2012 | 09:35 AM
GeoffreyM's Avatar
GeoffreyM
Duh. Thanks for the wake up call. I guess I'll just wait and have them do it when the recall letter comes to fix the spontaneous combustion issue with the water pump.
Old Feb 4, 2012 | 03:00 PM
yetti96's Avatar
yetti96
So how many miles until they are due? It does give a countdown. They won't do them unless you are 2,000 miles or sooner. Give them a call and see if you can get it all done at the same time. I had the recall fixed already without the letter.
Old Feb 6, 2012 | 03:41 PM
Flyer53's Avatar
Flyer53
GeoffreyM, My countryman was in for a I phone cradle issue which turned out to be faulty armrest wiring…so they overnighted a new one. While there they performed the W/P recall. I mentioned I hadn't received a letter yet, they said any vehicle that comes in for service and they confirm is part of the recall, they'll do it then instead of having you come back. They did front pads and sensors, rotors were still fine. They also did a upgrade to software in regards to the hesitation/stumble I would get on cold mornings. That's been corrected as well. Runs pretty sweet at the moment.So if you go in for the brake warning issue…long as your dealer has parts for the recall, they should do it.
Old Feb 6, 2012 | 03:57 PM
GeoffreyM's Avatar
GeoffreyM
Yetti-it says 900 miles
Flyer-Thank you for the heads up!
Old Feb 7, 2012 | 04:04 AM
yetti96's Avatar
yetti96
If you can wait get a bit closer, I went in at 1900 miles and was pretty bummed the pads were only changed, the rotors were still in spec even though they had a decent lip on them. :/
molala
Oct 2, 2015 01:53 PM
Tinklespout
16
Sep 6, 2015 11:39 AM
Sep 4, 2015 09:23 AM
PelicanParts.com
Tires, Wheels & Brakes
Sep 3, 2015 03:22 PM
Sep 3, 2015 02:06 PM
