Bolt pattern for 2012 Countryman S
Old Jan 18, 2012 | 07:18 PM
Bmw_ssg's Avatar
Bmw_ssg
I read here: http://www.motoringfile.com/2012/01/...ails-revealed/
That the bolt pattern for the CM is 5x120, correct? and that the bolt dimensions are 14x1.25. Am I reading this correctly?
If so, then most BMW 1 and 3 series wheels should fit (matched bolt patterns), right?
Does anyone know the maximum offset we can run?
Old Jan 19, 2012 | 11:02 AM
youthanasia's Avatar
youthanasia
I'm running +35 fine on stock sport suspension with no rubbing.I don't recommend going lower than that.
Old Jan 19, 2012 | 11:22 AM
Bmw_ssg's Avatar
Bmw_ssg
ok, I want to go with 18x8 (or 8.5) both front and back if possible and use the lowering springs from here: http://www.ebay.com/itm/H-R-SPORT-LO...-/320793059950
Old Jan 20, 2012 | 03:53 PM
Bmw_ssg's Avatar
Bmw_ssg
Would 18x9 fit in the back?
Old Feb 7, 2012 | 01:15 AM
kaikai114's Avatar
kaikai114
I just got my 18x8 35mm offset wheels today, gonna fit them with 245/40/18s to keep as close to stock diameter as possible.
18x8.5 35mm offset was on my list, but it would need the JCW bodykit for sure and i dont plan on getting that for a while, therefore got the 18x8 instead.
personally I think the 18x8.5 will look the best coupled with the JCW kit, but it's pretty much at the limits. I wouldn't recommend 9" wide rims, it'll look too pushed out for our car.
KC
Old Feb 7, 2012 | 01:03 PM
Bmw_ssg's Avatar
Bmw_ssg
KC
Thanks for the insight and info! Can you post pictures of your new wheels installed?
Thanks again!
SosoMINI
Nov 22, 2015 03:17 PM
tahoeruss
Aug 31, 2015 05:17 AM
Didicus71
Aug 28, 2015 02:00 PM
TOMSR53
Aug 26, 2015 10:18 AM
col127
Aug 21, 2015 02:11 PM
