Cooper (non S) Modifications specific to the MINI Cooper (R50).
Differences between 02-06 Cooper?
Old Jan 1, 2007 | 05:06 PM
Spitfire's Avatar
Spitfire
Hello,
I am wondering if there are any drivetrain or suspension (or anything else that could affect performance) differences between the Coopers from 02-06.
I need to know because the Cooper is classed in SCCA's G Production class and I am trying to straighten out the minimum weight specifications (I am on the rule making committee).
Old Jan 1, 2007 | 05:50 PM
UKSUV's Avatar
UKSUV
None that I know of....but I don't know much.
Old Jan 1, 2007 | 05:51 PM
UKSUV's Avatar
UKSUV
Oh yeah...besides the Midlands ---> Getrag transaxle change.
Old Jan 1, 2007 | 05:59 PM
gokartride's Avatar
gokartride
Theoretically in mid '03 there was a change made to less-stiff dampers. Not sure exactly when (or even if) this ever happened, but I'm sure there are some NAM threads/posts on the subject. It was hotly discussed at the time.
Here's one thread.
Old Jan 1, 2007 | 07:27 PM
UKSUV's Avatar
UKSUV
Oh yeah times 2...They changed the rear calipers from May 03 to present.
Old Jan 1, 2007 | 08:43 PM
fastcars's Avatar
fastcars
Tom,
The 2005 Cooper received an all new close ratio 5-speed Getrag manual transmission that replaced the old Midland Gears sourced 5-speed used from '02-'04. However, the Cooper did not see an increase of HP as the MCS did in 2005. This may be where the confusion is located.
The 2005 also had some styling changes in 2005. Here is the MINI USA Dealer Bulletin about changes made in 2005:
http://www.motoringfile.com/files/MINIhardtop2005.pdf
I think the 2002-2004 and 2005-2006 need to be listed on a different spec line unless you want to allow the Midland to Getrag swap. The Midland is **** to breaking.
Also the Convertible came out in 2005 and the spec line does not exclude or include the convertible.
Gear ratio information that I found on www.mini2.com
| G | |
| e | Overall |
| a | Ratio |
| r | |
| 1 | 13.463 | 14.400 |
| 2 | 7.671 | 8.327 |
| 3 | 5.252 | 5.476 |
| 4 | 4.153 | 4.105 |
| 5 | 3.333 | 3.509 |
| R | 14.105 | 14.065 |
| > 06/2004 | 07/2004 > |
Ron
Old Jan 2, 2007 | 03:39 PM
Spitfire's Avatar
Spitfire
Thanks for the replies. Since the production classes do not require vin numbers, they can all be raced with the same specs, IMO. That means that you could bolt a Getrag box into a 2002 Cooper.
Based on these answers, I believe they should be on the same spec line with the same weight, then add a note that either transmission is allowed. The chassis differences are parts that would be changed anyway for racing. I'll report this to the committee so that we can put the 2005 weight = to the 02-04 weight, then also add the 2006 car. Thanks again!
PS, build your SCCA GP Mini Coopers!
Aug 12, 2015 01:24 PM
ClayTaylorNC
Aug 10, 2015 09:19 PM
vballkid77
Cooper (non S)
Aug 10, 2015 04:44 PM
PelicanParts.com
Aug 4, 2015 02:45 PM
