Cooper (non S) Modifications specific to the MINI Cooper (R50).
cooper air pressure
Old May 24, 2006 | 02:42 PM
royce's Avatar
royce
cooper air pressure
what kind of air pressure are people running for the cooper?
Old May 24, 2006 | 03:21 PM
jimmy_racoon's Avatar
jimmy_racoon
Check door panel
It will depend on the tire and wheel size. I, for example, run stock 175-65R-15's and I follow the manual that says check the door panel on the drivers side. That says go with 35 PSI all around. Works for me.
Check it often, every other tank, since your driving style and the weather will affect pressure.
Motor on
Old May 24, 2006 | 04:27 PM
royce's Avatar
royce
i'm running the yoko avs es100 in 205/50/16 on the stock 5-star (16x6.5) wheels and was just wondering what pressures people use for aggressive street driving.
Old May 24, 2006 | 08:27 PM
scobib's Avatar
scobib
I normally run 32 psi on the street and it seems to work just fine... Ran it in the previous ES100's and I run that in my BFG G-Force Sports now...
The r-comps (Michelin Pilot Sport Cups) get 32 up front and 30 in the rear for autocrossing...
Old May 24, 2006 | 08:44 PM
xtremepsionic's Avatar
xtremepsionic
Motor on
On the same tire size here. I run 37 front and 41 rear for less understeer and slightly stiffer sidewall. From what I've seen on the tire depth gauge, it looks like 35 psi will give you perfectly even tire wear. At 37 psi front I get slightly more wear in the middle than the inside tire.
However, gas mileage is real good, I'm averaging 33MPG over almost one year in mostly city driving, but of course, it depends greatly on driving style and the type of "city" you're driving in.
andrewjg1994
Jan 29, 2021 07:45 PM
TREX
Nov 2, 2019 07:31 PM
Zettinger
Aug 25, 2015 04:04 PM
Ambient Thermal Management
Aug 7, 2015 12:27 PM
