Cooper (non S) Modifications specific to the MINI Cooper (R50).
Some help with lights.
Old Jan 21, 2006 | 12:19 PM
T-Boy's Avatar
T-Boy
Today out of no where i get a traction control light and run flat light on. What does this mean, and how do i fix it?
Old Jan 21, 2006 | 01:15 PM
not-so-rednwhitecooper
check the air pressure in all of your tires.
Old Jan 21, 2006 | 01:44 PM
Rally@StanceDesign's Avatar
Rally@StanceDesign
If you tires all seem fine, just press the reset tire button
Old Jan 21, 2006 | 01:46 PM
dave's Avatar
dave
pug poo picker-upper
Exactly.
Old Jan 21, 2006 | 02:02 PM
jimz68's Avatar
jimz68
Is your brake system warning lamp on ,also? If so, this could indicate a failure of one of your wheel speed sensors.
Jim
Old Jan 21, 2006 | 02:09 PM
thefuturequeenofnebraska's Avatar
I had the same problem after my accident... You have to go have the dealership reset both... and replace a wheel sensor...
Old Jan 21, 2006 | 06:41 PM
T-Boy's Avatar
T-Boy
No brake lamp warning....however i did try and press the reset button a couple times, and it didn't do anything. So i'll try and check all the tire pressure next. So if one of the tire pressure is low, it'll light both DSC and tire light at the same time and not go away?
Old Jan 21, 2006 | 10:12 PM
yes, it turns off abs and stability control, probably since the computer wouldnt be able to properly determine the aproximate air pressure in the tires and thru wouldnt be able to properly compensate for a spin or a quick stop.
you may have to drive for a while after you put the same pressure in all the tires before the lights co off.
Old Jan 22, 2006 | 04:17 PM
T-Boy's Avatar
T-Boy
Thanks for all the replies! I filled the tires up and reset, lights are all off now and normal. One other question....Is the powersteering always just loud? I checked fluids and everything. Just wondering if it's normal for coopers to whine.
Old Jan 22, 2006 | 10:24 PM
yeah, the pump isnt belt driven, its got an electric motor on the pump instead. your hearing the motor whine.
Old Jan 24, 2006 | 10:51 AM
T-Boy's Avatar
T-Boy
Cool thanks for the info.
Peking Duck
Jan 19, 2021 03:17 AM
JHolland
Sep 24, 2020 08:20 AM
navybsn
Oct 5, 2018 04:42 PM
Willafb
R55 :: Clubman Talk (2008+)
Nov 6, 2015 08:08 PM
Levers_and_Gears
Sep 28, 2015 04:42 PM
