Cooper (non S) Modifications specific to the MINI Cooper (R50).
Denso's Installed
Old Feb 1, 2006 | 02:55 PM
  #26
tools's Avatar
tools
the ik22 is for the S with the pulley changed. It is a colder plug. Unnessasary for the Mini.
Old Feb 2, 2006 | 12:48 AM
  #27
daflake's Avatar
daflake
Went out to the Denso WEB site and there is no listing of plugs for the 05 or 06 MINI. The 04 MINI has the IK20 listed with the gap preset from their factory .032. There must be a reason that the vendor has not listed them for the 05/06 models......
If the vendor is not recommending them, it is probably a good idea not to use them.
Old Feb 2, 2006 | 03:53 AM
  #28
Wagnbat's Avatar
Wagnbat
Laziness?
Old Feb 2, 2006 | 04:04 AM
  #29
sndwave's Avatar
sndwave
Coordinator :: Gulf Coast & Panhandle MINIs
The Denso's come pre gapped so no need to worry about that. If you've never used them, you'll understand why you can't gap them once you see one.
I've been using the 22's for a couple years now and can say they're a great plug.
Old Feb 2, 2006 | 07:27 AM
  #30
Hulles's Avatar
Hulles
yea id have to go with wagnbat and say the denso site is just lazy about updating that info ha Ive seen alot of 05 minis with these plugs in them..and it seems most of the top mini tuners use them as well...so im sure they work fine ^_~
DM
Old Feb 2, 2006 | 01:43 PM
  #31
scobib's Avatar
scobib
FWIW, RSpeed has IK20's and IK22's on sale for $49.95 a set...
Old Feb 2, 2006 | 02:23 PM
  #32
petecrosby's Avatar
petecrosby
If you happen to have a NOPI parts store in your area, they have them for $10.29 each.
Old Feb 5, 2006 | 08:59 AM
  #33
retroom's Avatar
retroom
Find IK20 for $42 including shipping on EBAY. The plugs were listed for an Acura. This is my second set, the first set was bought for the MINI, same packaging same gap, same plugs.
IK20 on EBAY, buy it now price $32.99 + $7
Search Ebay Motors using "Denso Iridium IK20".
retroom
Old Feb 11, 2006 | 03:38 PM
  #34
DragonSlayer's Avatar
DragonSlayer
http://cgi.ebay.com/ebaymotors/Denso...37007280QQrdZ1
These would be the correct ones?
Old Feb 12, 2006 | 12:14 AM
  #35
retroom's Avatar
retroom
Should be fine.
retroom
Originally Posted by DragonSlayer
Old Feb 12, 2006 | 02:31 PM
  #36
DragonSlayer
The Results of the research are as follows
These are for the 2003 Mini Cooper
NGK IX iridium 6418 BKR6EIX 0.032$6.95
And These would be for the 2003 Mini Cooper "S"
NGK IX iridium 6441 ZFR6FIX-11 0.045Supercharged$6.95
Found it difficult to research the Denso IK-20's The Denso web page would not offer up the part # or price and as you can see stated that the gap was .044 for the Cooper and the Cooper "S" The part # may be IK20 for the Cooper and IK22 for the Cooper "S". I just couldn't verify it.
YearMakeModelEngineIr PowerGap2003MINICOOPER1.6 L - L40.044 2003MINICOOPER S1.6 L - L40.044
Essentially Iridium is Iridium is Iridium and the NGK's seem to run cheaper.
Old Feb 12, 2006 | 11:55 PM
  #37
retroom's Avatar
retroom
True, the NGK's are a little cheaper than the Denso. However, the electrode on the Denso is 0.4mm and the electrode on the NGK is 0.6mm. I've used both and prefer the Denso's.
Retroom
Old Feb 13, 2006 | 08:16 PM
  #38
DragonSlayer
I guess most what i find disturbing is the disparity in gaps between the NGK's and the Densos
Old Jul 1, 2006 | 11:09 AM
  #39
sandtoast500's Avatar
sandtoast500
I've got the Denso IK20s in the mail.
http://cgi.ebay.com/ebaymotors/ws/eB...MEWN%3AIT&rd=1
So are they pre-gapped? No messing with gap? For sure? ok...
And torqued to 22 ft lbs? for sure? alright...
So basically the IK20 is only one specific kind of plug. ALL IK20s come with the same gap, specs, etc... There are not different kinds of IK20 plugs with different gaps, etc... right? seems to make sense but u never know with some companies...
Any comments are welcome!
-Steve
Old Jul 1, 2006 | 11:50 AM
  #40
mistro's Avatar
mistro
yes not sure that the last link was agood one but here is one...
http://cgi.ebay.com/ebaymotors/DENSO...QQcmdZViewItem
Are these the plugs you are suppose to run if you change your pulley?
Old Jul 1, 2006 | 03:04 PM
  #41
mr_edly's Avatar
mr_edly
I think the IK22 are the commonly recommended colder plugs for a reduced s/c pulley. But some don't change the plugs at all.
https://www.northamericanmotoring.co...highlight=ik22
Old Jul 1, 2006 | 03:08 PM
  #42
holdenontoit's Avatar
holdenontoit
yup. Ik 22 is the right one ,and they come pregapped.Check the torque often as they are known to loosen and eventually blow.
Old Jul 1, 2006 | 03:44 PM
  #43
resmini's Avatar
resmini
What are the original equipment plugs in an 03' MC?
Old Jul 1, 2006 | 08:48 PM
  #44
Flyer's Avatar
Flyer
Denso doesn't offer plugs for th elater MINI's because they changed the gap on them in 05. The same plug will work just fine, the gap change is prolly done for emission purposes.
Iridium plugs are not to be gapped. The tip can and will be damaged if gapped. (read, DO NOT GAP THE DENSO IRIDIUMS)
22's would be a colder plug than 20's, so increased boost for an MCS or increased compression would be a reason to run them. Otherwise, you might get a noticable random miss at idle speeds. The colder plugs have a tendancy to detonate LESS than a warmer plug, although, if not needed, they will also foul out easier than the hotter plug. The hotter plug gets hotter than the cooler plug, therefore allowing the carbon deposits that build up to burn off. The boosted or higher compression engines have hotter cylinder pressures, therefore benefitting from a cooler plug.
Old Jul 1, 2006 | 09:58 PM
  #45
CooperSS's Avatar
CooperSS
Currently running IK24s. Brrrr really cold.
My Cosworth MTH load has a ton of timing & the 24s seem just fine.
As you could expect they don't like to idle for long, but they sure hold down the detonation above 7000 with California's crap gas.
These are not the plugs for everyone, but they do work great on a highly modded setup.
Bill
Old Jul 2, 2006 | 08:56 AM
  #46
Tio Barry's Avatar
Tio Barry
Original plugs in my 2003 MC CVT were BKR6EQUP
Replaced them at 36k with ZFR6F-11's - ca $2 ea. - smoothed out the idle and drivability.
I imagine MINI/BMW chose the 4 prong plug so they could claim 100k service.
Old Jul 2, 2006 | 09:20 AM
  #47
sandtoast500
Great, but we are in the non-S forum, so any answers to my questions are welcome.
For a regular justacooper MC, 2005, 5 spd, not supercharged:
Denso Iridium IK20, standard gap from the plug factory, torqued to 22 ft lbs.
Is this correct?
Old Jul 2, 2006 | 10:35 AM
  #48
CooperSS's Avatar
CooperSS
I apologize for posting in the non-s forum, I just saw the title of the thread and not the forum it came from.
MC Power forever
Bill
Old Jul 2, 2006 | 10:46 AM
  #49
Dr Obnxs's Avatar
Dr Obnxs
To stirr the pot a bit...
I'm running IK-24s right now. These run even cooler than the IK-22s. The idea behind cooler plugs is to get more heat out of the combustion chamber to fight timing retard. the 91 octane CA gas isn't that good, and every bit helps.....
As for torques, I've used 18 ft lbs, the Bentley manual says 20. But at 20 the head sure feels soft..... 22 would scare me a bit.
And for gapping, you CAN gap a denso plug. Just be VERY CAREFULL and use a wire plug gauge, not the feeler gauge types... My 24s came at 0.065 or MORE out of the box, so I regapped them to .045 or .055, I don't remember which....
And I too bought from that eBay store... Under $40 shipped, can't be beat! Some places want to charge well over $15 per plug, before tax and shipping!
Matt
Old Jul 2, 2006 | 04:10 PM
  #50
resmini's Avatar
resmini
The reason for switching to the $10.00/each Denso plugs is.................?
If there is an actual performance gain, $40 is cheap, if not, I'll go for the $2.00 plugs.
