Cooper (non S) Modifications specific to the MINI Cooper (R50).
need help regarding header
Old Nov 4, 2005 | 11:11 AM
CNred's Avatar
CNred
I have my header unbolted now but i can not get the flange part of it by the sway bar, how do i get it througth the bottom?
Old Nov 4, 2005 | 11:34 AM
Torkor's Avatar
Torkor
Behold! Thy prayers have been heard. This link will help. (Thanks Randy)
Tormod
Old Nov 4, 2005 | 11:43 AM
sfjames2's Avatar
sfjames2
that how to will tell you what to remove, but not how much of a pain it actually is.
My ONE piece of advise is to lift the car as high as you can off the ground so that you can move the header around and guide it out. I say get it as high off the ground as you can assuming your working off the garage floor like I did. It won't clear the plastic lines under the heat shield perfectly, but it'll come out. have fun and ok now it's 2 pieces of advise...be patient.
Old Nov 4, 2005 | 12:34 PM
CNred's Avatar
CNred
ok i have 4 bolts on the new header but i can not get the ones that are close to the tubes on because of the large head on the bolts, what can be done here to fix this problem?
Oct 1, 2015 12:34 PM
Oct 1, 2015 12:13 PM
PhoR53
Sep 30, 2015 06:54 AM
Sep 29, 2015 12:17 PM
Sep 29, 2015 12:11 PM
