Cooper (non S) Modifications specific to the MINI Cooper (R50).
Cooper (non-S) 2006 R50 - manual & auto engines the same?
Old Sep 30, 2021 | 08:32 AM
AlphaBob's Avatar
AlphaBob
Sorry for the question if it has already been addressed - no luck finding the answer on my end. Specifically, is the engine the same in a 2006 automatic transmission and manual (5-speed) transmission? I've got a 2006 R50 with a manual transmission and a bad engine. I've got a line a decent 2006 R50 engine which was equipped with an automatic [blown] transmission. Can I simply swap the engines? Or is there anything unique to either the automatic or manual transmission from an engine standpoint?
Old Oct 1, 2021 | 11:56 AM
Thinker2112's Avatar
Thinker2112
Other than the ECU's, the engines should be identical. Each car's ecu's will be programed for the type of transmission the car was equipped with and to my knowledge, won't work with a different transmission. I would think that you would just keep your old ECU and it should work.
Old Oct 2, 2021 | 05:28 AM
AlphaBob's Avatar
AlphaBob
That’s my thinking exactly. I haven’t pulled the trigger yet, but if I do I’ll make sure to post the outcome.
Old Oct 4, 2021 | 09:41 AM
thmpr464's Avatar
thmpr464
The airbox is different.
Old Oct 5, 2021 | 01:02 PM
Thinker2112
@thumper464 - while true; I think that the OP wouldn't need to swap that out. If the OP's just looking to swap out the full block and head they can leave all the other bits alone and reuse their original bits - like the airbox and such.
r53-06m6
May 26, 2019 08:54 PM
coopermike29
Apr 18, 2017 03:23 PM
rphox2003
Aug 5, 2015 11:34 AM
silence2-38554
Northern California
Mar 28, 2015 04:10 AM
itsminibtch
14
Apr 17, 2010 10:55 AM
