Cooper (non S) Modifications specific to the MINI Cooper (R56).
Cooper (non-S) Drop In Filter Options
Old 08-19-2014, 05:27 AM
ECSTuning is online now
Received 1,967 Likes on 1,767 Posts
Washable and reusable on the aFe , aFe also has a dry filter if you don't like to re-oil. More surface area. Rubberized / poly seal on the outside.
  #27
Old 09-09-2014, 07:54 AM
kyoo's Avatar
kyoo
kyoo is offline
thinking about this again.. what are the exact dimensions of the stock air filter for the base cooper?
::edit::
365mm x 130mm
currently doing research to find what is the best FILTERING filter - usually k&n doesn't top that list, seeing how aFe will be.
Looks like the oiled version is going to be very good filtering-wise - however, it is oiled and would require some maintenance. I've tried re-oiling a filter in the past, did not enjoy.
The dry version has slightly less filtering efficiency, but with the convenience of being a dry filter.
The "racing" version will have the best flow, but worst filtration
http://afepower.com/technology_detail.php?tech_id=5
07-16-2020 12:54 PM
minicoclub
08-25-2015 09:07 AM
bc219
08-10-2015 11:22 AM
Ambient Thermal Management
08-07-2015 12:27 PM
08-07-2015 08:02 AM
Quick Reply: Cooper (non-S) Drop In Filter Options
