Cooper (non S) Modifications specific to the MINI Cooper (R50).
Arch Lamp Bulb Replacement
Old Dec 23, 2011 | 04:28 PM
JLRAMEY's Avatar
JLRAMEY
What's the trick to removing the rear arch lamp in order to replace the bulb? Just pry it out? 2003 Cooper. Thanks!
Old Dec 25, 2011 | 12:43 AM
vkash1208's Avatar
vkash1208
bump
Old Dec 25, 2011 | 05:07 AM
HRM's Avatar
HRM
You take off the wheel, then the liner and go from the inside. Really only need to take off that side of the liner.
I am pretty certain that using the search function would have answered this for you faster.
Old Mar 3, 2021 | 09:37 AM
Cehlers's Avatar
Cehlers
R60 Countryman rear side wheel are bulb replacement
Hey there I have seen links to replacing the bulb for the rear wheel arch marker, well on my 2015 countryman, if you lay on your back directly under the exhaust pipe and look up to the left or right, depending in the side you need to replace, you will see the socket for the bulb. Slightly cramped but it is accessible and requires no tools, but maybe a skinned knuckle.
Old Mar 3, 2021 | 10:28 AM
deepgrey's Avatar
deepgrey
Yeah, you can't do that on an R50.
andysinnh
Sep 6, 2021 01:22 PM
DouglasLive
Sep 3, 2013 09:14 PM
choupette
Aug 20, 2011 09:35 AM
ahanas
Jun 24, 2011 02:23 AM
Glas4d
May 30, 2008 04:26 PM
