Cooper (non S) Modifications specific to the MINI Cooper (R50).
Reasonable R50 performance mods
Old Dec 15, 2007 | 08:02 AM
FP's Avatar
FP
Without breaking the bank; what are some reasonably priced performance mods available for the R50? Not looking to spend a ton of money, otherwise I would just trade it in for an 'S'.
Anyone made some performance mods that are reasonable? Not including suspension.
Old Dec 15, 2007 | 08:51 AM
AutoXCooper.com's Avatar
AutoXCooper.com
PM sent
Old Dec 15, 2007 | 09:13 AM
minihune's Avatar
minihune
OVERDRIVE - Racing Champion
Most base Cooper owners are looking for reasonable mods.
Search this forum for past ideas.
All MINIs can be enhanced by-
If manual transmission- whalen shift ****, short shift kit
Light rims- 15x7 or 16x7, OEM rims are very heavy
Non runflat tires- 205/55-15 or 205/50-16
Suspension upgrades-
Shocks (Koni FSD)
Springs
Rear swaybar- adjustable 19mm for the base cooper
Brakes- better pads try Hawk brand (ceramic for less dust)
Intake- looks nice, works a little
Cat back exhaust- sounds nice, might be lighter, works a little
ECU flash- MTH software
Spark plugs wires
Old Dec 15, 2007 | 10:12 AM
Chilipeppa03's Avatar
Chilipeppa03
I believe that suspension upgrades is the key to make a Cooper faster by far!It totally changes the way the car feels in going down the road and taking turns. It is a great upgrade since the Cooper takes more effort to get more power out of the motor!
Old Dec 15, 2007 | 10:51 AM
Speedwing's Avatar
Speedwing
My H&R 19mm rear sway bar is my favorite mod. I also bought 16 inch R90s from Morristown MINI and shod them with Kuhmo 205/50-16 ASTs. This combo made a huge fun factor difference. The K&N drop in was also a good mod.
Old Dec 15, 2007 | 11:04 AM
Beecher's Avatar
Beecher
how much is reasonable? the jcw sound kit is 880 from morristown, new intake, new exhaust, new ecu (which will be like 150 to have installed, you could do the rest is so inclined...). I havnt got mine on fully yet, because im going to mod the header, which would probably be a good thing for you to do as well, 180 on ebay for an obx, or remove the pre cat on your stocker, would help more than a cat back probably. But $1000 for a nice package, and bit of jcw bling.
Old Dec 15, 2007 | 11:28 AM
FP's Avatar
FP
That's not bad and it's at the limit of what I would want to spend. After all of this is done, what do you gain in HP?
Old Dec 15, 2007 | 11:57 AM
cristo's Avatar
cristo
Alliance Member
I'd like my Midlands transmission to last forever, and that precludes adding
a lot of power to the Cooper (also, it's hard to add lots of power to the
Cooper anyway).
But, .... If my transmission goes, I think I'd get a 5 speed Getrag or preferably
a 6-speed MCS Getrag to replace it, and if I was going to sink that much into
the car, I'd probably consider adding a cylinder head ported for an NA engine
in mind and a header (hopefully a 4-2-1 design with a cat and not too wide
primaries) to add to the intake, milltek cat-back and bluefin ecu reprogram
I already have. I'm pretty sure the MC short block can handle that.
Would also want to use a lightened flywheel if using the MCS transmission.
The MCS oem one is way to heavy at 28# compared to 18# for the MC oem one.
Old Dec 15, 2007 | 12:29 PM
UKSUV's Avatar
UKSUV
Can I just say...I love my Cooper...It's such a POS....
Old Dec 15, 2007 | 03:11 PM
rkw's Avatar
rkw
I have the Sound Kit and love it, but gain in real HP is negligible. The throttle is more responsive and the exhaust and intake sound are very nice. I like it enough that I would get it again.
For real power gain without breaking the bank, your best bet may be a custom tune such as Revolution Motor Works: https://www.northamericanmotoring.co...03#post1921603.
Old Dec 15, 2007 | 03:51 PM
Chilipeppa03
Dude that MINI is sexyy!!
Old Dec 16, 2007 | 05:16 AM
snid's Avatar
snid
What aspect of the car's performance are you trying to improve?
Suspension is the easiest way to make a Cooper faster on a track, but you said no suspension.
An exhaust and intake will make it sound fast, but it will not actually make the car go fast. The Cooper Borla exhaust sounds great, and with a cone air intake it sounds very impressive.
Old Dec 16, 2007 | 06:20 AM
FP's Avatar
FP
Well I'm a spirited driver, but don't track it. I don't enter any competitions. I'm already in the process of upgrading my standard suspension to the 'S' sport suspension including the sway bar I bought from a NAM member. I'm just want to maximize the performance of my current drive train platform. I don't want to open the engine or anything that invasive.
Old Dec 16, 2007 | 08:14 AM
blue_bomber's Avatar
blue_bomber
im curious as to how many times the same question can be asked... then in return, get the same responses.
in most cases i would think the cooper would not be the first car the person asking has modded. also not likely that NAM is the first forum they have joined. so what im getting at here is that you should know better.
search. its real easy.
but in light of the thread, heres my 2 cents-
its a NA 4 cylinder. theres not going to be any top secret single part, for any price, that is going to lay down an impressive gain in power.
i understand what your looking for. and i hate it when people say suspension and/or driving schools will make you faster (not everyone is a twisty junkie). suspension will prove its self on a timed lap, but not faster according to the butt dyno while ripping down a straight on ramp.
now, for $800 you could do alot more for yourself and your car IF you DONT buy parts that are unreasonably expensive. ebay intakes work all the same as those poorly made K&N's. its a bent tube with a filter...., youll save $200. exhaust, buy a muffler and a tip online, take it to a shop to have it welded in, save at least $150. with the left over money you could go even further than you initially expected.
if this is your hobby, take some pride in it. your time will be well spent/invested and in the end your mini will be your masterpiece.
now its up to you to not take anyones advise and go buy the more expensive parts that have the same gains (that tends to be the leading trend).
</rant>
and yes, that felt good
Old Dec 16, 2007 | 08:18 AM
FP's Avatar
FP
</rant>
I like the way you think my friend.
Old Dec 16, 2007 | 08:21 AM
blue_bomber
thank you
Old Dec 16, 2007 | 02:48 PM
Chilipeppa03
What is done to your car Blue Bomber
Old Dec 16, 2007 | 04:19 PM
blue_bomber
right now, just an alta drop in and a homemade exhaust consisting of a bosal muffler (mostly a glorified glass pack), removed front resonator and self made tip.
next autocross season im moving to STS. so in the spring, when the snow is gone i will be installing H-sports and an "S" rear bar, both iv already acquired. still need to pick up a set of designated summer wheels and tires.
Besides that, just cosmetics; blacked out all chrome, painted wheels (next years winter wheels) and fog lamps.
Old Dec 16, 2007 | 08:06 PM
Chilipeppa03
Got any pics?
Old Dec 17, 2007 | 07:04 AM
blue_bomber
really only one from an autocross. isnt close up and is also pre fogs-
Old Dec 17, 2007 | 01:31 PM
hemiheaded18's Avatar
hemiheaded18
Wanna go faster? It won't be NA anymore, but you could always spray it. Come on, don't such a sissy mary...kidding. That takes a lot of *****.
Old Dec 17, 2007 | 05:44 PM
Chilipeppa03
wow that really is blacked out!
Old Apr 1, 2021 | 12:09 PM
joe oxberry's Avatar
joe oxberry
Blue fin chip are 150 quid and highly recommended in the UK just waiting on delivery and will let u know
Old Mar 2, 2023 | 01:20 AM
adriancl's Avatar
adriancl
Best way to get more power is to use 270cc injectors plug and play( are used on old Lincoln 5,4l V8,Bosch 0280155865) and a good remap.Made this on my R50 and also on lot of R50.
6 gears Getrag from MCS is a good move also.
Old Mar 3, 2023 | 02:25 AM
JerBear's Avatar
JerBear
I have said injectors and an mpps v21, short the laptop to hook it up though. Do you recommend a wide band or have you tuned enough of these to just reflash and go?
