Engine
Old Mar 24, 2007 | 03:32 AM
kamikazy's Avatar
kamikazy
Engine
Hello
Can I convert my 998 cc engine to 1275cc or 1275cc+
Any idea?
Old Mar 24, 2007 | 10:10 AM
Minimad's Avatar
Minimad
If you mean can a 998 become a 1275 by boring or stroking, the answer is no.
You can remove the 998 from the trans and install a 1275 though.
BTW, I have a friend that has one for sale cheap - $650 with trans. It should be inspected and refurbished before install. It had excellent compression and oil pressure when I checked it.
Old Mar 24, 2007 | 12:07 PM
kamikazy's Avatar
kamikazy
do you have any pic of it ?
Old Mar 24, 2007 | 03:38 PM
shorn's Avatar
shorn
Minimad, where's the engine located?
Steve
Old Mar 24, 2007 | 07:17 PM
Minimad's Avatar
Minimad
Lakeland FL
http://www.sunshineminis.org/forums/...ic.php?t=12472
Old Mar 25, 2007 | 11:43 PM
kamikazy's Avatar
kamikazy
Can i use this --> Half Engine Kit or Short Engine Kit
Old Mar 26, 2007 | 02:50 PM
Minimad's Avatar
Minimad
Yes, but shipping from the UK is a killer.
I'd prefer the short kit cuz you'd wanna spec your cam for intended use and put in a new oil pump anyway. Plus this kit you need a 12G940 (big valve) cylinder head to take advantage of the displacement. Add in an 1 3/4" SU, intake manifold, LCB manifold and a larger RC40 exhaust too....it adds up fast.
Your alternative is to take the 998 you have and build it with the Stage 1 or 2 kit offered. The prob with stock engines is breathing. While there is no substitution for displacement, intake, exhaust & head mods can significantly help the 998.
Old Mar 26, 2007 | 02:53 PM
kamikazy's Avatar
kamikazy
^^ thank you for your help
Old Mar 29, 2007 | 05:34 AM
pmustang's Avatar
pmustang
Just to add fuel to the fire, Putting a stage one kit on your 998 and some head work and you basically have a basic 1275 type of powerband.
Everyone wants 1275s so your not alone but I have driven some wickely strong 998s, Tony M in Florida blew past me in my 90hp converted 1275 MPI mini in his 998 mini, Okay, he is a lifetime british car mechanic but it shows what can be done with a Normally aspriated 998.
Sure saves a lot of money to not change engines.
Cheers. Peter
Old Mar 29, 2007 | 05:44 AM
shorn's Avatar
shorn
So, as one with a 998 and a stage 1 (1-1/2" SU, Mini Sport manifold, LCB) already in place, your recommendation to me would be to replace the head with a 12G940 instead of replacing the 998 with a 1275? 'Nigel' runs pretty good, but is still a little flat on exceleration. I'm thinking it could be a timing issue or something like improper dashpot oil damping or some other SU issue. I still need to explore further. BTW, this is just a 'road' car; not one used in races, autocross, etc.
Old Mar 29, 2007 | 07:36 PM
Minimad's Avatar
Minimad
You don't mention what exhaust system? Air cleaner?
Old Mar 29, 2007 | 07:50 PM
shorn's Avatar
shorn
K&N wannabe filter, dunno the exhaust - I don't know the car's history and am not familiar with the Mini exhaust systems.
Old Mar 30, 2007 | 04:29 AM
Minimad's Avatar
Minimad
the RC40 is the "gold standard" for Minis, either single muffler or twin depending on how much noise you like. I've found the twin perfect for a sporty sound w/o sacraficing performance.
Old Mar 30, 2007 | 10:15 AM
shorn's Avatar
shorn
Dumb question: How can I identify an RC40 exhaust? Looking under the car, I've got (well, it has) twin mufflers and single 2" SS tailpipe. And to me, it sounds pretty sweet.
Old Mar 30, 2007 | 02:16 PM
STLMINI's Avatar
STLMINI
Originally Posted by shorn
...your recommendation to me would be to replace the head with a 12G940...
That's what i've done to mine and my mechanic tells me it runs like a stock 1275. I've also replaced my exhaust and have a k&n CAI. That's about all I've done performance-wise.
Old Mar 30, 2007 | 03:59 PM
Minimad's Avatar
Minimad
The muffler on an RC40 is stamped "RC-40", clever, huh?
Larger pipes do not mean better performance, necessarily. The LCB comes in two diameters for large bore & small bore motors, for example. The larger pipe will slow exhaust gasses down in a small bore application. The A-series is very dependent on maintaining certain flow characteristics. Same goes for intake mods.
You should obtain a copy of David Vizard's "Tuning the A-series" engine or "How to modify your Mini" and read through it before embarking on the project or shelling out major $$$.
Old Mar 30, 2007 | 04:02 PM
Minimad's Avatar
Minimad
LCB sizing per MiniMania:
LCB SMALL BORE MANIFOLD 1.5 OD OUTLET -MINI & MINI COOPER S
Small bore Maniflow LCB. This is the only manifold to use of you want the ultimate performance from your 998/1098cc engine. Not only do these manifolds fit without the use of a hammer, they work fantastic, allowing you to get the maximum performance from your engine!
Standard bore LCB (1-3/4"id) that is ideal for very hot small bore Mini or Mini Cooper engines, for standard to high performance Mini Cooper 1275s, and for street Mini Cooper 1380s.
Large bore LCB for competition use or on very large bore street engines; such as 1400cc+. Y-piece outlet end is 2" outside diameter, 1.875"id.
Old Mar 30, 2007 | 04:08 PM
Minimad's Avatar
Minimad
Head info:
http://www.minimania.com/web/SCatago...2/ArticleV.cfm
David.R53
Sep 1, 2015 06:49 PM
Aug 21, 2015 10:07 AM
finn
Aug 21, 2015 07:59 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
