BROKEN Mini.....
BROKEN Mini.....
I just got my Mini back and throuout the day, sometimes in downshifting, sometimes in accelerating, sometimes downshifting I'd get a thump from my engine bay. Thinking if related to engine mounting as I just added a flip-front, I paid it little mind thinking I'd have a look at it tomorrow.
So I am driving home from dinner and a louder thump followed by the engine cutting out with no smoke, fumes, liquids leaking out the bottom, and no cracks in the block that I can see I had a broken Mini again.
The Mini turns over, but does not start. Anyone have any guesses as to what may be wrong with her?
The link below is for any florida members so I will more likely see your replies faster on Sunshine Minis.
Thanks, Lance
http://www.sunshineminis.org/forums/...ic.php?t=10650
Thanks, Lance
It may be indirectly related to the thumping you heard. The thumping could be caused by a few things... although the engine mounts would be the first things I'd check. Then suspension. Whatever is shifting may have shorted out and/or cut the ignition system.
Follow the primary leads from the distributor to the engine bay harness and makes sure everything is in order.
Make sure you're getting voltage at the ignition systemwhile it's cranking.
2. Worn throw-out bearing (similar disengaging issues).
3. Worn syncros in the trans. Does it grind less if you shift slower or pause slightly between gears?
Not sure what else it could be.
When I drove my friends' '73 850, shifts had to be slow and deliberate or they would grind.
daviday
09-25-2015 01:31 AM
