Front brake flare
Old Aug 8, 2006 | 08:47 PM
MINI-IZED's Avatar
MINI-IZED
Front brake flare
Has anyone had any luck making the flares on the front brake lines? Is there a special tool, or do you just use a double flare tool without making the double flare?
Old Aug 9, 2006 | 04:20 AM
Minimad's Avatar
Minimad
You should be able to make the flare successfully. It is a double flare but not compressed back on itself. Also, you must use the correct union nut. The british are different from american ones. The american ones will not seal even the proper flare.
https://www.bmc.on.ca/storeFront/store/index.asp
Old Aug 11, 2006 | 09:40 AM
elprofe's Avatar
elprofe
YES, THERE IS A PROPER TOOL.....Matco makes a good one, but if it's not worth the money....it may be cheaper to buy the lines you neeed.
Old Aug 11, 2006 | 10:09 AM
Minimad's Avatar
Minimad
You may be able to get the proper tool from any Mini supplier
minimania.com, MiniCityLTD.com, djminis.com, BMC.on.ca or 7ent.com
W0TM8
Dec 19, 2019 07:50 AM
thebordella
Aug 31, 2015 01:37 PM
FLYM1N1
Aug 15, 2015 11:20 AM
Khai
Aug 12, 2015 06:20 PM
