Bonnet wont release
Old Apr 20, 2006 | 07:06 AM
bmrking1's Avatar
bmrking1
Bonnet wont release
Just ran into another problem last night. I tried to release the bonnet so I can gain access to the engine, I pulled the lever inside the car, the bonnet released (can see hear the sound). But when I got to the front I can't get to the catch mechanism. Is there another way to open the bonnet?
Old Apr 20, 2006 | 04:50 PM
OKeefe's Avatar
OKeefe
Well......
Inside hood release .... OMG
I don't even have hinges!
Sounds like you need to go hunting...the cable is binding somewhere.
But don't feel messed with. I spent 2 hours last nite trying to find out why the wire stopped feeding in a MIG welder....same problem....and I finally finished the job on the Camaro....
Old Apr 20, 2006 | 04:56 PM
Jim Ray's Avatar
Jim Ray
There is a way. Take off the inner fender liner from the Right side front, and you can reach in and release the latch. I have seen the cable slip off the bracket. Not as hard as it sounds. Jack the car up and support securely, take the wheel off.
Old Apr 22, 2006 | 01:31 PM
Xanthus's Avatar
Xanthus
Coordinator :: South East - Florida
Funny thing, this can happen on the new ones too.
And you need to get the wheel off for that fix too...
GL with that, I now know what to do should I have this issue.
Old Apr 23, 2006 | 05:12 AM
Hotelcalif's Avatar
Hotelcalif
This is a classic Mini? I don't have fender liners. The easy way is to remove the grille and you can get to the latch.
Old Apr 23, 2006 | 06:32 AM
Jim Ray's Avatar
Jim Ray
Sorry, I was reading new posts and did not check what forum I was in. Good luck, sounds easier than on a New MINI.
And, I was wrong there too. If you can't tell what side is not releasing, both inner finders have to be removed.
Back to you BJ.
Old Apr 23, 2006 | 03:59 PM
OKeefe's Avatar
OKeefe
not me
Back to you BJ.
I've no quick fix for this. My 79 has a glass front end. No inside release...no hinges. Pull 2 pin and release 2 rubber straps and the bonnet comes off. 4 more rubbers. 6 screws, 2 banjos and one electric multi point and the entire front clip comes off
Old Apr 24, 2006 | 12:20 PM
Jdewey's Avatar
Jdewey
If you can hear it release, then the cable is still hooked up. While you are pulling the release inside the car, have some one play with the hood, They may be able to get it off of the catch. I have had that problem with several cars. The hood is just "stuck" so it does not pop up off of the latch with spring pressure alone.
John
Old May 8, 2006 | 09:36 AM
bmrking1's Avatar
bmrking1
I resolved the issue. I took off the front grill and was able to release the bonnet. The latch/spring was off center so I bent it back to center it up and now it works great. Thanks everyone for your help.
gnhovis
Dec 14, 2015 05:31 PM
Island maser
General Discussion
Oct 1, 2015 01:09 PM
jennster
Sep 28, 2015 06:19 PM
Sep 25, 2015 11:46 AM
Sep 25, 2015 11:44 AM
