Fuel Gauge Not Working
Old Mar 31, 2006 | 09:34 AM
bmrking1's Avatar
bmrking1
The fuel gauge on my 75/93 Mini Sprite isn't working. Can anyone tell me how I can check it to see what the problem might be?
thanks
Old Mar 31, 2006 | 09:53 AM
Dr Obnxs's Avatar
Dr Obnxs
It's either the sender or the guage....
You can try shorting the sender wire to ground and see if the guage moves. If it does, then the sender is shot. If it doesn't, then it probably the gauge.
Oh yeah, disconnect the sender wire as well. You should get a full swing of the guage from open to shorted to ground.
Matt (at least that's what happens on my Mustang....)
Old Mar 31, 2006 | 03:41 PM
mini33's Avatar
mini33
I would check the fuse and power to the unit first. Then try the ideas suggested above... Hope this helps... Good Luck
Old Mar 31, 2006 | 08:59 PM
STLMINI's Avatar
STLMINI
Forgive me for post-jacking, but can the fuel gauge be calibrated? mine show's full until it's about 4 gallons then quickly goes to empty and there's 1.5 gallons left.
Old Mar 31, 2006 | 09:03 PM
Dr Obnxs's Avatar
Dr Obnxs
New car or old...
New I don't think so, old all work on a variable resetor in the sender unit. You can play with other resistors, or just bend the arm on the sender to get other effects. There's a company in OR or WA that makes capacitive units. They can make them so that empty corresponds to one resistance, and full another, and you can get anything you want.
For the new cars, I have no clue!
Matt
silence2-38554
98
Sep 21, 2016 02:52 PM
David.R53
Sep 1, 2015 06:49 PM
dchang0
Aug 10, 2015 03:37 PM
bc219
Aug 10, 2015 11:22 AM
