Allignment
Old Dec 31, 2005 | 08:36 AM
Xanthus's Avatar
Xanthus
Coordinator :: South East - Florida
Allignment
What are all the #'s needed for someone to do my allignment?
I found a guy that has the right equiptment and does not look at me puzzled when I tell him what my car is and he cannot find it in his computer, but tells me I need the numbers for it in order for him to do the allignment.
Where can one find this?
Old Dec 31, 2005 | 09:06 AM
fred3's Avatar
fred3
Why not use the dealer?
"alignment" has just one "l". Thought you'd want to know. :-)
chows4us's Avatar
chows4us
wrong info
Old Dec 31, 2005 | 01:12 PM
OKeefe's Avatar
OKeefe
You guys realize he's talking a classic, right?
Curiously - as you may know - the Haynes manual doesn't give these numbers. Altho gives a procedure for adjustment - wierd.
From the Heritage CD, I haven't found this in the tech manuals.... the owner's manuals all provide only 1 number
toe out 1/16 inch (1.6 mm)
I'm gonna dig in the CD some more. I'll need this eventually too
Old Dec 31, 2005 | 01:27 PM
chows4us's Avatar
chows4us
OOPS, I am SORRY. DIdnt even see that
Old Dec 31, 2005 | 01:39 PM
OKeefe's Avatar
OKeefe
no problem
you got my attention by mentioning a Bentley manual for classics
If my 79 has ways to adjust that much on a stock susp I haven't found it!
Old Dec 31, 2005 | 07:30 PM
Minimad's Avatar
Minimad
Unless you put in adj suspension components (tie rods, lower arms, rear brackets) you can only adj front toe.
Specs:
http://www.minimania.com/web/SCatago...8/ArticleV.cfm
http://www.ime.org.uk/ime/s/suspension
Lance, why post multiple boards for an answer that's easily available on Minimania.com tech section. :impatient Also, re-check your posts to see that people have already answered your questions....
Old Jan 1, 2006 | 05:24 PM
Xanthus's Avatar
Xanthus
Dealer???
CLASSIC Mini man, not a "dealer" to be found for some years...
Old Jan 1, 2006 | 05:26 PM
Xanthus's Avatar
Xanthus
Specs:
I am impatient, but you know that, and I am not familiar with the Mini Mania site.
Besides this worked I got the info.
Thanks bud!!!
Old Jan 3, 2006 | 04:59 AM
OKeefe's Avatar
OKeefe
Mini Mania site
Thanks bud!!!
The MM site is a pain in the gearbox to use so far as their boards go. I searched there for the same info and found nada - however since I find the board so hard to use (heck, it is hard just to find the boards much less how to sign-on) I also posted a ? there. With no reply after several days.....
The shopping side isn't bad, but the boards
Old Jan 4, 2006 | 02:41 PM
MiniManiac74's Avatar
MiniManiac74
The minimania site isn't going to give you much info. The guys there told me "a little toe out on the front and a little toe in on the rear."
If you do not have adj suspension, you will only be able to adjust the toe. I have fully adj suspension, but my numbers are at home. I will post them up when I get home. My set-up is working very nicely. I think it is a little trial and error dependent upon what type of driving you do.
Again, when I get home I will post up my specs
Old Jan 4, 2006 | 04:13 PM
MiniManiac74
Alignment Numbers
If you have adjustable lower control arms, adjustable tie rods and a new rear bracket for the rear radius arms you can make the following adjustments. Keep in mind that all of these are in DEGREES.
Front:
Toe .09 toe out
Caster 3.5
Camber 1.2 neg
Rear:
Toe .09 toe in
Camber .6 neg
I am very happy with this ride. If you do not have the adjustable components, I highly recommend them. The difference in the drive is absolutely worth it.
Old Jan 18, 2006 | 03:19 AM
minimad jr.'s Avatar
minimad jr.
Although I seem to be going there more often for info and getting more acclimated to it, I must say that the minimania site could do with a facelift and software upgrade. It's the most outdated and un-user-friendly Mini site out there.
my $.02
Old Jan 18, 2006 | 01:07 PM
CasaMini's Avatar
CasaMini
You think that's bad try www.minispares.com.
CasaMini
Old Jan 18, 2006 | 02:13 PM
pooch1's Avatar
pooch1
Old Jan 18, 2006 | 03:52 PM
OKeefe's Avatar
OKeefe
no arguement
CasaMini
As a new (2 years) classic owner....I concur
anyone care who I've gotten good service from??????
besides this site, obviously
mustgetwet
Jun 16, 2011 07:24 AM
mattcubed
Tires, Wheels, & Brakes
15
Apr 14, 2011 12:52 PM
Un0RiGiNaL
Suspension
25
Apr 13, 2010 06:23 PM
usman88
Suspension
Sep 9, 2007 06:40 PM
Hound_va
Suspension
Dec 11, 2006 01:10 PM
