Shopping List - Front Disc Conversion
Old Sep 26, 2005 | 03:29 PM
gtbuzzmini's Avatar
gtbuzzmini
I will be converting my front drums on my '75 austin to discs and want to make sure I have everything i will need before I get started (I am not so mechanically inclined so help!). I will be keeping my 10s and going with the 7.5" setup. Any help is greatly appreciated.
Here's what I have so far:
brake calipers, New pistons, seals, and pads
I know i need the 7.5" cooper s rotors, but what else will I need? Thanks as always.
Matt
Old Sep 26, 2005 | 04:42 PM
Minimad's Avatar
Minimad
Check the threads on minimania.com on this topic. MM also offers the full conversion as a kit. The have photos of it which may help you.
http://www.minimania.com/web/Item/MM.../InvDetail.cfm
I've converted to 8.4's not 7.5's. So don't have first hand knowledge but it looks pretty similar.
The outer CVs on a Cooper S are larger in diameter than the drum brake set up so you'll need them and hubs/bearings too.
Old Sep 27, 2005 | 03:06 PM
CasaMini's Avatar
CasaMini
Beside the parts in the picture you will also need backing plates which don't come in the kit and brake hoses which also don't come in the kits.
Maddog
Old Sep 27, 2005 | 04:27 PM
namwob's Avatar
namwob
You will probably also need a brake master with a larger capacity reservoir. Displacing fluid behind the large caliper pistons could suck your drum master dry! Notice the difference in the parts books. Also the bore within the master is likely to be a different diameter. Excelent move getting rid of the front drums
Old Sep 28, 2005 | 04:47 AM
joltfreak's Avatar
joltfreak
I just went from drums to disc brakes. but i went with Honda civic vented brakes and was able to keep my 10 inch rims p[lus it was a lot cheaper anf IMHO a better system check it out http://joltfreak.tripod.com
Old Oct 3, 2005 | 08:47 PM
Scott Miller's Avatar
Scott Miller
I can see a couple things that are missing from that picture...inner and outer rubber CV boots and I'm not sure but you may need new uprights when changing from drum to disc.
Old Oct 4, 2005 | 08:20 AM
joltfreak's Avatar
joltfreak
not with the Honda set up. you use your existing mini parts all that i reconmend that you upgrade your wheel bearing the that tapered type. if you have any questions please feel free to contact me ( joltfreak@gmail.com ) and/or check out my web site ( http://joltfreak.tripod.com )
Wohnson89
Jun 10, 2020 04:53 AM
Powershift
Aug 16, 2015 05:14 PM
FLYM1N1
Aug 15, 2015 11:20 AM
Minibeagle
Aug 13, 2015 10:00 AM
