The Mini Therapist
Old Feb 22, 2005 | 07:45 AM
NSXguy's Avatar
NSXguy
The Mini Therapist
Hello Classic Mini aficionados. I come from a long line of Mark I Minis and was active in the Mini Owners of America, San Francisco chapter from the late ‘70s until the mid ‘90s. I currently autocross an ’03 Cooper. I recently came across some stuff that I wrote for the program of the National MOA East Meets West Convention in Denver in 1984. Thought you might enjoy reading the following:
The Mini Therapist
Dear Doctor:
My problem is that my lover can’t make up his mind to live with me or his wife. What can I do? Bruce, San Francisco
Dear Bruce:
Changing polarity is a relatively simple task. First, connect the positive terminal on the battery to the main feed and the negative to ground. Then brush the smaller of the two wires to the dynamo against a hot lead to set up the regulator for negative ground.
Dear Doctor:
I can’t seem to get any reaction from my girlfriend when we kiss. Isn’t there something I can do to turn her on? Frustrated, San Diego
Dear Frustrated:
he front suspension nipples are easily located and they need periodic attention. If they are dry, use a recommended lubricant. The entire chassis will not function properly for long unless these nipples are serviced as described.
Dear Doctor:
I can’t seem to keep it up any more. What can I do? Pooped Out, Cleveland
Dear Pooped Out:
Shaving your head may give you more compression and enable you to keep up with the traffic. Don’t overdo it, however, as you may experience some bothersome pinging.
Dear Doctor:
I’m confused. Just what are the advantages and disadvantages of the various birth control methods? Safety Conscious, Denver
Dear Safety Conscious:
There are two systems: wet and dry. The dry set up has a rubber cone as a damper. It can be adjusted for ride height with some difficulty by lengthening or shortening the struts. The wet system uses a fluid in a rubber bag which can be pumped up easily and gives a comparatively comfortable ride. Both are equally safe.
Dear Doctor:
My boyfriend doesn’t know when or how to stop when we get romantic. It’s go, go, go every time! What can I tell him? Still-a-virgin-but-barely, Vancouver
Dear Still-a-virgin-but-barely:
Disc brakes give the best stopping power. A vacuum booster can be added, but this will only making stopping easier, not necessarily faster. If this equipment is unavailable, twin lead shoes will halt the action nearly as fast.
Dear Doctor:
My husband is a graduate of the wham-bam, thank-you-mam school of romance. He needs help! Longing-for-leisure, New York
Dear Longing-for-leisure:
Drive gears can range from high speed to cruising ratios. A 2.9:1 final drive will slow down the RPM’s considerably, at some expense in power. A more relaxed atmosphere is created with this modification.
Last edited by NSXguy; Feb 26, 2005 at 08:04 AM. Reason: No more formatting clutter
Old Feb 22, 2005 | 07:46 AM
NSXguy's Avatar
NSXguy
That didn't work!
Problem solved
Old Feb 22, 2005 | 08:23 AM
Johnna's Avatar
Johnna
Originally Posted by NSXguy
Sorry about the Mini Therapist post- I tried to paste from Work, but obviously it didn't work.
It's a little hard to read but entertaining none the less! More please.
Dec 23, 2015 10:36 AM
Dashdog
Aug 10, 2015 06:17 AM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
