Cooling Issue
Old May 1, 2011 | 04:35 AM
or birdman's Avatar
or birdman
Cooling Issue
My new Mini I just finished has a lg aluminum radiator, a 180 degree thermostat, and a elec fan set to come on at 180 degrees.
Day time driving the engine runs at a steady 200 degrees, according to gauge and verified with a heat gun. And the heater works just fine.
At night the engine runs at 180 to 190 degrees and I get no heat out of the heater, just cold air.
Any ideas?
Old May 1, 2011 | 12:05 PM
joltfreak's Avatar
joltfreak
maybe you have some air trapped in you system.What type of fan are you using? i would recommend that you get a tropical fan if you don't have one. I also run an electric fan to pull air through my rad. it helps when driving in town.
Old May 1, 2011 | 04:14 PM
Capt_bj's Avatar
Capt_bj
I think you are too cold at night and the therm is not opening
I'd pull the fuse from the electric fan for a time and let the car run w/out it.
If you had not said you had heat during the day I'd suspect a clogged heater hose or a stuck or incorrectly installed valve for the heater . . .
p.s. I run a tweeked 1275 in Florida with a stock radiator and have no overheat issues. I did once when the car was smack new 2 me. It over-heated within 20 minutes of ownership. I stopped, smaked the thermostat housing with a hammer, cooled 'er down and have not had another problem in 7 years . . .
Are you moving the heater valve pull at all during your 'tests'?
Old May 2, 2011 | 03:08 AM
or birdman's Avatar
or birdman
I am not using the engine fan, just the elec. fan.
Old May 2, 2011 | 03:13 AM
or birdman's Avatar
or birdman
Yes I have moved the heater valve. It's also new.
So here's what I am thinking.
Durning the hot day, with the 180 degree thermostat open the engine runs 200.
At night when it's cooler, the thermostat doesn't open, so I don't get any heat. If I go to a 190 degree thermostat, I'm thinking durning the day I'll still run 200 but at night 190 with the hotter thermostat, am I thinking right?
Old May 4, 2011 | 01:52 AM
or birdman's Avatar
or birdman
Yesterday I put a 195 degree thermostat in. Put about 40 miles on it durning the day and the water temp stayed at 200. I haven't drove it at night in colder temps yet.
Old May 6, 2011 | 03:09 AM
or birdman's Avatar
or birdman
It's working great, staying at 200 day time, and 190 at night with plenty of heat.
Old May 6, 2011 | 04:34 PM
joltfreak's Avatar
joltfreak
glad you got it sorted
iggi
18
Feb 9, 2026 01:00 AM
Kimolaoha
Jul 5, 2023 01:04 PM
Bruce/Fl
Aug 28, 2015 11:59 AM
L3Mix
Aug 26, 2015 07:00 PM
robbiedowns22
Aug 25, 2015 12:20 PM
