Master Cyl Rebuild ?
Old May 13, 2010 | 07:10 PM
oc00l's Avatar
oc00l
I have a 95 spi mini with a "green tag" master cyl. I got a rebuild kit for it at minimania, started taking it apart found some helpful info on theminiforum but I am stuck I cannot get the piston out there is some sort of plastic washer I cant get out any ideas?
Thanks!
Will
Old May 15, 2010 | 02:22 AM
1071s's Avatar
1071s
Try using a low pressure air hose to force piston out of cly?
Old May 15, 2010 | 08:33 PM
minimk11959's Avatar
minimk11959
look inside the upper resevoir hole and ther is a pin that comes out and the piston then comes out
Old May 16, 2010 | 03:11 PM
oc00l's Avatar
oc00l
Got it out with Air pressure. I did actually figure out the pin, it was a plastic washer that is very tight.
Thanks guys!
Will
drrigg
May 27, 2022 03:31 AM
Fordgt4
Oct 10, 2015 10:42 AM
Oct 1, 2015 12:13 PM
Tires, Wheels & Brakes
Oct 1, 2015 10:38 AM
Oct 1, 2015 10:17 AM
