New engine in classic mini?
Old Apr 30, 2010 | 07:00 AM
Nitrocrusher's Avatar
Nitrocrusher
I'm new to the forum and have driven an 04 MC for the last 6 years. I am considering buying a classic mini and had a thought the other day. I'm just curious and I doubt it's even possible, but could a new Mini (BMW) engine and drive train be fitted into an 80's or 90's classic Mini? Is this even physically possible? Thanks for any input.
Old May 1, 2010 | 12:35 PM
radgator1's Avatar
radgator1
I suppose anything is possible with enough money but for practicality's sake, no it is not possible.
Possibilities for increasing BHP in a Mini (BMW MINI's are MINI's, not Mini's fyi) include upgrading the A series engine with any combination of increasing Bore, different pistons, porting and polishing, hot Cams, upgraded rockers, exhaust, etc. Then there are options of adding forced induction to A series engines. Finally there is the possibility of adding a 16 valve head to the A series block.
As far as fitting completely different engines/transmissions, the 2 standard options are Honda V-Tech conversions (with or without stretching the front end) or fitting a motorcycle engine of all things:
http://www.zcars.org.uk/mini/index.htm
Do lots of research before buying a Classic Mini. It can be a love/hate relationship and will take lots of time and money to own a car that isn't likely to be fit for reliable transportation.
Old May 1, 2010 | 04:41 PM
joltfreak's Avatar
joltfreak
there are many other engine options that would go into a mini much easier and aloso produce the same or more HP than the MINI.
Old May 1, 2010 | 06:43 PM
Tall Mini's Avatar
Tall Mini
...what they said. You are more than welcome to try however as it would be cool
The thing most people forget is that you don't need much extra HP to take a classic to 11 on the fun meter. The car only weighs in at below 2000 lbs so the power to weight quickly moves into the nuts realm (and into the area where you begin to blow past usable HP numbers.)
Old May 1, 2010 | 07:45 PM
Red Riley's Avatar
Red Riley
Also look here: http://superfastminis.com/index.htm
And as long as you're picking nits, it's VTEC, not V-Tech
Old May 1, 2010 | 07:52 PM
radgator1's Avatar
radgator1
Opps, you're right, I always do that, VTEC it is.
Old May 4, 2010 | 08:52 PM
dimini's Avatar
dimini
Awe VTEC. Put one of those in a classic and lose the british charm. That is, you will go out to the garage and start the car--everytime, without fail.
Old May 5, 2010 | 05:36 AM
Red Riley's Avatar
Red Riley
I just leave one of the battery cables loose to keep some of the British feeling.
09R56
Nov 16, 2022 10:49 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
calebmil
Aug 7, 2015 05:54 AM
M7Speed
Aug 6, 2015 01:48 PM
