Problem with engine ID number
Old May 24, 2009 | 04:17 PM
lgraff06's Avatar
lgraff06
Hello everyone, im a first time post and forgive my ignorance but i have a bit of a problem, i have a 1972 1100 (1098) mini, but aparently the Engine identification plate is missing, i know it should be beside the water pump, well close by on the block, is there anywhere else i can find the id number for this engine, the problem is here where i live all license plates have been changed and in order to renew them they have to check the motor number which i cant find, and if not available what could you recomend.. i really apreciate any help you can provide.
Regards, Lawrence
Old May 24, 2009 | 08:11 PM
stratman977's Avatar
stratman977
There's probably some casting numbers stamped into the back of the block which may point you to the type of engine. Theres not going to be a full id number though. I had a similar problem in which my engine has a tag but its not the correct one. This writeup was helpful: http://www.mgcars.org.uk/engine/mgenginehistory.rtf
Old May 24, 2009 | 10:07 PM
Juiceman's Avatar
Juiceman
Here is a picture of my 1100 sitting on the floor.
Old May 25, 2009 | 05:34 AM
Minimad's Avatar
Minimad
The ID plate is roughly 1/2" x 2" and is reversed stamped and riveted to the top of the block on the right front side. You'll see a small flat landing there.
You can still buy the plates & rivets
If you knew what the original number was (available from British Motor Heritage) you can order a new plate up & install it. Your number would've started 10XXXx
http://www.minimania.com/web/SCatago...0/ArticleV.cfm
I think MiniMail or Nick at Min-e-bitz in the UK does them or can put you on to someone who does.
http://www.minimail.co.uk/
http://www.min-e-bitz.com/index.php?...sr2vco4bh7fh17
Or, you can go to Harbor Freight and buy a number punch set and stamp the block yourself.
Old May 27, 2009 | 08:10 AM
lgraff06's Avatar
lgraff06
Thank you very much for all your replies, i am going to purchase the stamped plate in the UK ..
Does any one know where the chasis and commission plate should be located?
Kimolaoha
Jul 5, 2023 01:04 PM
Zettinger
Aug 25, 2015 04:04 PM
Mini Cooper r56 Pr
Aug 12, 2015 07:42 PM
Aug 12, 2015 01:24 PM
wind715
Aug 11, 2015 07:56 AM
