Electrical Parts Questions
I have a couple of questions on electrical parts that I am having some trouble locating the right part for.
The first is the bulb holder/connector for the turn signal lamp that pushes into a cup on the back of the speedometer..... It is a 2-wire connector. the one in the picture grounds out and renders it non-functional and has a split down the housing.
The second is a plastic holder that the wires for the rear light assembly push into. One of mine is broken and needs replaced.
Thanks for any assistance!
Auto Sparks
also available from britishwiring.com
British wiring is the US supplier for Auto Sparks, and with the Pound being so down its usually cheaper to order direct from the UK
I'm not sure about the second part, my car had the same problem, You can just put some heat shrink tubing over the connectors to insulate them.
07-16-2020 12:54 PM
Getrieben
08-15-2015 09:09 PM
