Cone compression tool
Old Jan 13, 2009 | 10:31 AM
OKMini's Avatar
OKMini
I have already removed the subframes from my '79 Mini and was able to remove all of the suspension components including the cones & trumpets, etc. I have new cones and just ordered a set of HiLo's today for the rebuild process. I was able to get everything apart relatively easily as the subframes were on the garage floor and I imagine the cones were compressed from the original size.
Is it reasonable to assume that I can reassemble the new cones, knuckles and HiLo's without purchasing the cone compression tool? Or was the disassemble process just a function of wear that I will not have when I reassemble?
Since everything going back together is upgraded and new (ka-ching!) I am trying to save on buying something that I may not need. I do not anticipate doing this again for quite some time!!
Old Jan 13, 2009 | 12:22 PM
elprofe's Avatar
elprofe
yes
Old Jan 13, 2009 | 02:52 PM
minimk11959's Avatar
minimk11959
if nothing else put the one and hi*lo in then the arm ,slide the nuckel in the arm then put the arm in the subframe Easy Classic ji
Old Jan 13, 2009 | 03:53 PM
Classic Blimey's Avatar
Classic Blimey
No need for a compressor if you are installing Hi-Los. I have done it with no problem.Just compress the Hi-Lo and everything should install easily.
Old Jan 13, 2009 | 04:16 PM
OKMini's Avatar
OKMini
Good deal.......Thanks!
Steffen.Johnson
42
Jan 25, 2023 02:47 PM
Fordgt4
Oct 10, 2015 10:42 AM
Debi's Coop S
Oct 3, 2015 08:19 AM
aldito2
Sep 30, 2015 10:44 AM
silence2-38554
Sep 28, 2015 12:19 PM
