Alignment Specs
Old Aug 21, 2008 | 06:11 PM
Iced1nk's Avatar
Iced1nk
Alignment Specs
Does anyone have alignment specs for a rover mini that I can give to my local Big O tires. Am in great need.
Thanks all.
you help is appreciated
[SIZE=3][FONT=Times New Roman][/FONT][/SIZE]
Old Aug 24, 2008 | 04:53 PM
Capt_bj's Avatar
Capt_bj
Stock suspension?
If so the only adjustment you can make is toe...1.58mm toe-out
see also https://www.northamericanmotoring.co...ight=alignment
Other adjustments need replacement of fixed parts with adjustables, or disassembly and replacement of shims.... http://www.minimania.com/web/Item/C-.../InvDetail.cfm
Haynes chapter 10.....has the full stock numbers tho
front
caster 3 degrees plus/minus 1 positive
camber 2 degrees plus/minus 1
swivel hub inclination 9 deg 30 min
if there's adjustment points other than toe on a stock susp I haven't found 'em.
MrBlah
SCCA Solo and ProSolo
Feb 1, 2020 07:43 PM
Keet
Suspension
Aug 30, 2016 03:46 PM
wildwestrider
11
Jan 29, 2016 05:06 PM
Willafb
R55 :: Clubman Talk (2008+)
Nov 6, 2015 08:08 PM
gnhovis
Sep 28, 2015 10:56 AM
