possible grounding problem?
Old Aug 21, 2008 | 10:58 AM
ahwest's Avatar
ahwest
I'm having a weird problem recently that the tachometer gauge and the voltage gauge stop working for a while; however when i a hit a bump or something they will come back on and then somehow stop working again.
i was thinking whether i have a loose ground wire of these two gauges?
obviously they are somehow connected together since they are the only two gauges acting weird, the rest are fine.
does anyone know how could i fix this problem? thanks.
Old Aug 25, 2008 | 02:39 PM
Capt_bj's Avatar
Capt_bj
your cause sounds like a good possibility and there's not much you can do except trace the wires.....are these factory gauges...what year and model? That would help me try to find some help in the wiring diagrams....
Mine doesn't have either as a factory mount. My tach is added so it is easy to trace the ground wire.....
arf88
May 31, 2016 03:07 PM
LordOfTheFlies
Oct 19, 2015 05:02 PM
SolCalMini
Aug 29, 2015 07:25 PM
Aug 19, 2015 12:51 PM
Aug 12, 2015 01:24 PM
