What type of clutch fluid to use?
Old May 7, 2008 | 06:10 PM
jeffm5150's Avatar
jeffm5150
I'm working through a clutch adjustment issue and have been bleeding the hydraulic system. Can I use DOT3, DOT4. or DOT5 fluid with these hydraulic systems or do I need to actually buy the Unipart 410 or 550 brake fluid as specified in the factory service manual?
As wierd as this sounds, I *think* the previous owner was using Zenith damper oil for clutch fluid.
Oh, and the clutch is pre-verto.
Thanks for any help!
Jeff
Old May 7, 2008 | 10:51 PM
MINIxB's Avatar
MINIxB
I don't know anything about clutches but I use DOT 4 brake fluid for my brakes (you mentioned brake fluid in your post...)
Old May 8, 2008 | 06:50 AM
1FSTMINI's Avatar
1FSTMINI
the clutch uses the brake master as a res....dot 4 is fine.
Old May 8, 2008 | 08:40 AM
IanF's Avatar
IanF
Castrol LMA is generally considered the "default" brake/clutch fluid for older cars. Mainly because it doesn't react badly with the natural rubber seals that many British hydraulic systems use/used.
Old May 8, 2008 | 09:38 AM
1FSTMINI's Avatar
1FSTMINI
wow...i didnt even notice im in classic talk....bubye
patsum
26
May 29, 2021 06:29 PM
rob76turbo
GP Talk (2006)
Sep 7, 2015 12:28 PM
wildwestrider
Sep 4, 2015 06:25 AM
Sep 3, 2015 02:06 PM
