tune-up parts
Old Feb 17, 2008 | 01:56 PM
vic170's Avatar
vic170
tune-up parts
I want to give my classic mini a tune-up but I will like to know if I can buy parts in R & S or pep boys auto like distributor cap, fan belt thermostat, ignition wires, sparks plugs etc...
Old Feb 17, 2008 | 03:05 PM
elprofe's Avatar
elprofe
fan belt, you must remove and match up.
spark plugs ask for 73 MG Midget.
Other items must be ordered from your regular english car supplier.
Old Feb 17, 2008 | 03:40 PM
joltfreak's Avatar
joltfreak
you can also use a delco alternator and the following oil filters will also work:
AC-DELCO 93156323
HASTINGS LF155
K&N HP-2004
K&N HP1002
LUCAS F5578
MOBIL M1-102
MOPAR 4105409
NAPA 1374
PIPERCROSS OF106
PIPERCROSS OF106-RBT
PUROLATOR L10028
PUROLATOR L10241
STP S3614
UNIPART GFE148
UNIPART GFE166
UNIPART GFE21
WALMART ST3614
WIX 51374
AC-DELCO PF53
AMSOIL SDF-57
BALDWIN B288
BECK/ARNLEY 041-8988
BOSCH 3330
BOSCH 72150
CASITE CF966
COOPERS GFE1
COOPERS Z25/2
DELPHI FX 0004
FRAM PH2870A
FRAM PH3600
Fram3682
Valvoline VO22
Ryco Z418
Fram PH3816
Lee LF2835
BOSCH 72161
WIX 51348
Car Quest 85374
FRAM PH3506 (for an MPI)
FRAM PH3614
FRAM PH966B
Old Feb 17, 2008 | 03:44 PM
Mini Mania's Avatar
Not impossible, but the real challenge is often trying to make sure what model/year your classic really is. Hope this help: http://www.minimania.com/matrix/
Sure that Min Mania can help if don't want to take a chance:
http://www.minimania.com/home.cfm
Old Feb 17, 2008 | 04:07 PM
Minimad's Avatar
Minimad
Cap, rotor, points, condenser, belts, plugs & oil fitlers are all available. Source using a 1275 MG Midget as a reference, then double check they match.
NGK BP6ES plugs.
Any issues or to remove all doubt call Don for OEM quality parts. In fact, before replacing your ign points spend $100 and get the Pertronix Ignitor replacement. Trouble & maintenance free. Best upgrade you can do.
Old Feb 17, 2008 | 04:43 PM
MINIxB's Avatar
MINIxB
What oil filters in the US work for the automatic?
Old Feb 17, 2008 | 08:57 PM
Rocan's Avatar
Rocan
I'm pretty sure its the same as for the manual counterpart of you engine
Old Feb 17, 2008 | 09:22 PM
MINIxB's Avatar
MINIxB
I think it said on GB Car Parts that they're different...
Old Feb 17, 2008 | 09:23 PM
elprofe's Avatar
elprofe
mg parts fit the pre A+ motors.
Old Feb 17, 2008 | 09:39 PM
Rocan's Avatar
Rocan
Do you have a link or something? im almost positive their the same
Old Feb 18, 2008 | 03:23 PM
Minimad's Avatar
Minimad
Defo NOT the same spin-on!
Cartridge type.
http://www.minimania.com/web/Item/GF.../InvDetail.cfm
Or Advance Auto:
http://www.partsamerica.com/ProductL...for=Oil+Filter
Old Feb 18, 2008 | 06:28 PM
Rocan's Avatar
Rocan
huh, and here i was thinking they're the same
Old Feb 18, 2008 | 11:22 PM
MINIxB's Avatar
MINIxB
Originally Posted by Minimad
That's the one. Your Advance auto link doesn't go to a oil filter.....
Old Feb 19, 2008 | 03:48 AM
Minimad's Avatar
Minimad
Look up 1968 Austin America oil filter. They list both a spin on and a cartridge filter for that year automatic (must have been a change) BUt Can't be sure if they are correct until you see it. You know for sure with Minimania.
Old Feb 19, 2008 | 03:50 AM
Minimad's Avatar
Minimad
Beck/Arnley Oil Filter
Part Number: 0418913For Your VehicleVehicle: 1968 AUSTIN AMERICAEngine: L4 1.3 Liter CarburetedOil Filter: Manual Transaxle See all vehicles this product fits [SIZE=1](click image for full-size view)[/SIZE]PricingOur Price:$7.44 Availability
  • Ships in 1 business day (1.80 lbs.)
Warranty[FONT=arial, helvetica][SIZE=2]90 DAYS FREE REPLACEMENT [/SIZE][/FONT]
Link works for me just fine......
Old Feb 19, 2008 | 03:51 AM
Minimad's Avatar
Minimad
Minimania's looks like a better filter...
Old Feb 19, 2008 | 10:25 AM
MINIxB's Avatar
MINIxB
The filter I have looks alot bigger than that one too.
Old Jan 5, 2010 | 03:12 PM
trigga71's Avatar
trigga71
I didn't want to start a new thread as this one has some good info in it already. But does anyone know about getting a thermostat gasket for a 998 from a local parts store? Like a part number or car make/model to give.
Old Jan 5, 2010 | 04:02 PM
Capt_bj's Avatar
Capt_bj
why risk it
given the low low cost of an item like this and the low cost of shipping why risk it and not buy from a Mini expert like Seven or MiniMania?
if I were really trying to save a buck in this situation I'd Just buy gasket material, pull the old one and trace it on the flat stock and cut it out. Cost a couple of bucks and was what I had to do when I changed out my mechanical fuel pump for which no one had a gasket. (been going solid for close to 6 years now)
Any part store has sheets of gasket material for a few cents
Old Jan 5, 2010 | 04:29 PM
trigga71's Avatar
trigga71
Not trying to save a buck just wondering if I can get it local. I've been getting parts from seven ent. so I'll stick with them. Fast shipping and had every part I needed. I have been thinking about going to a electric fuel pump, why did you stay mech.?
Old Jan 6, 2010 | 07:14 AM
Capt_bj's Avatar
Capt_bj
- the fuel pump ended up being the first thing I had to do to the car ... when I got home the pump was leaking like crazy. Only research I did was finding a direct replacement of what was there.
- that said, I've had no problems with it so why introduce another potential electrical gremlin if it isn't needed? I don't suffer any fuel starvation which to me would be a primary reason for going to electric ... increased vol' if needed.
- altho I might add that changing the mechanical pump was a chore with everything else in place. Not the easiet beast to access, the two bolts are somewhat buried under the exh' manifold. I ended up adding toys to the tool box just to get in there....but would have had similar problem if swapping to elect' as the old would still come off and would be replaced by a blanking plate. I used the opportunity to replace all the fuel lines, and did some rerouting as I was not thrilled with how close the existing stuff came to the manifold in places - you'd obviously end up doing some of this if changing to electric too. Bottom line is it was probably the same if not more work to hold onto the mechanical.
Old Jan 6, 2010 | 08:58 AM
trigga71's Avatar
trigga71
Very valid point on the electrical aspect. My Mini has odd problems, got the head lights working fully and now the instrument lights don't work. Once it warms up Im going to take the gauges out and check connections. i just found 2 wires that are cut, a black and a green w/ red wire. never ends, but its fun.
bobbiemartin
Jan 20, 2016 05:28 PM
ryGuyMCS
Oct 20, 2015 02:24 PM
Ryephile
Aug 25, 2015 06:51 AM
nomar116
Aug 21, 2015 04:36 PM
