Mini SPi running lean
Old Jan 23, 2008 | 08:58 AM
Supra 21V's Avatar
Supra 21V
I am looking to put a supercharger on my mini, so I had a leak down test done on it. It turned out great, but when I pulled the spark plugs I noticed they were a bit on the light side. Anyone know how to adjust these to make it more rich?
Also anyone seen the supercharger in action? Thank you.
Old Jan 26, 2008 | 12:08 PM
miniroll's Avatar
miniroll
There is no adjustments (sorry) As with any fuel injection, the amount of fuel shot into the cylinders is based on several sensors that inputs to the computer in which controls the amount of fuel thru the injector. With that said, I would check the fuel pressure first and then test each sensor to be sure it is within factory range. Now putting a superscharger on it, you are going to have to get the computer tuned for what it is going to need to make it run good. Hope this points you into a good direction.........
Old Jan 26, 2008 | 01:29 PM
elprofe's Avatar
elprofe
THERE is a UK company that sells teh complete kit with a tuned ecu.
Old Jan 27, 2008 | 07:14 AM
Supra 21V's Avatar
Supra 21V
Thank you I will check that, I should probably put a fuel pressure guage in anyway.
minicoclub
Aug 25, 2015 09:07 AM
bleonard1401
Aug 11, 2015 02:53 PM
Minii cooper bean
Aug 11, 2015 02:10 PM
Lt. Dan
Aug 10, 2015 12:46 PM
