Classic mini refuses to motor =(
Old Dec 28, 2007 | 08:03 PM
richi0207's Avatar
richi0207
I have a fuel injected 96' Rover mini. I recently got it and drove it around without a problem. One day I was driving and turned it off, then I tried to turn it on and it just doesnt stay on.The car starts but when I let go of the gas it turns off. I need to leave my foot on the gas to remain on. Any ideas on what it can be? Thx
-Richii
Old Dec 28, 2007 | 11:55 PM
plkdb's Avatar
plkdb
Have you tried pulling the codes from it yet? I would think based on the year, it would have OBD II.
Old Dec 29, 2007 | 06:23 AM
stratman977's Avatar
stratman977
I don't know specifically about your engine, but that sounds like a vacuum problem. If your engine has vacuum lines check those.
Old Dec 29, 2007 | 08:41 AM
richi0207's Avatar
richi0207
Alright thanks Ill check the vacuum hoses and if the problem consists Ill pull the obd codes. thx guys
Old Dec 30, 2007 | 12:01 AM
a8ked's Avatar
a8ked
Check your electric fuel pump fuse. My 90's Rover SPI has a 20amp fuse for the fuel pump. If the fuse blows you can get a similar result to what you are having. On my car it is fuse #11.
Old Dec 30, 2007 | 05:11 PM
a8ked's Avatar
a8ked
Ooops! I just checked my car today the fuel pump fuse is a 10amp not 20amp.
There is also a 10amp fuse that controls the fuel pump relay and engine management system. Check these two fuses this may be a simple and cheap repair!!
Old Dec 31, 2007 | 03:32 PM
richi0207's Avatar
richi0207
Ill give them a check. If it was the fuel pump fuse i figured it wont start.
Dec 23, 2015 10:36 AM
tr3y003
Oct 22, 2015 10:48 AM
minimaximum
R55 :: Clubman Talk (2008+)
Aug 14, 2015 04:05 PM
wind715
Aug 11, 2015 07:56 AM
kwijmbo
Aug 5, 2015 09:00 PM
