Carburetor Needles Question
Old Jul 3, 2007 | 02:27 AM
kamikazy's Avatar
kamikazy
Can I change the needle in my mini & if I can what is the best needle for my HS4 carburetor?
Old Jul 3, 2007 | 04:17 AM
joltfreak's Avatar
joltfreak
it depends on what motor, cam, exhaust & air filter that your running as well.
Tamer
Old Jul 3, 2007 | 06:31 AM
elprofe's Avatar
elprofe
the best needle is the one that suites your engine and makes it run right and get the most ponies out of it.
Old Jul 3, 2007 | 09:18 AM
MINIdave's Avatar
MINIdave
What needle is in there now, and what are you trying to accomplish by changing it (besides more power?) Choosing the right needle is a bit complicated, as the others have noted. I'd leave it alone unless you've made other changes to the engine.
Old Jul 3, 2007 | 12:38 PM
kamikazy's Avatar
kamikazy
i have stock engine.
i need smooth running + some power.
Old Jul 3, 2007 | 01:22 PM
elprofe's Avatar
elprofe
needles are needed when you ad some performance parts like stage 1 stuff.
Old Jul 3, 2007 | 04:17 PM
Minimad's Avatar
Minimad
What HS4 do you have? Is it a Capstat (Waxstat)? If so, get a rebuild kit to replace the problematic jet tube.
Best SU parts & friendly advice available at www.joecurto.com
Just need to judge needle profiles?
Try: http://www.beavispits.co.uk/winsu/winsu.html
Old Jul 3, 2007 | 04:21 PM
Minimad's Avatar
Minimad
as elprofe said, a stage 1 kit = aluminum intake manifold, K&N filter, new needle, lcb exhaust manifold, RC40 exhaust Best $$$ you can spend for the results.
Old Jul 3, 2007 | 08:00 PM
kamikazy's Avatar
kamikazy
thank you alot guys ^^
eliseo1981
May 10, 2016 05:19 AM
donniedarko
Oct 21, 2015 01:15 PM
PSU 98
Sep 11, 2015 11:20 AM
cinnabun
Sep 11, 2015 05:55 AM
Robree
Sep 9, 2015 08:43 AM
