Chicago MINI Motoring Club The Chicago MINI Motoring Club Forum. Visit our club site at www.chicagominiclub.com
2003 manual gear shifter stiff.
Old Apr 14, 2008 | 01:52 PM
Sindbog's Avatar
Sindbog
I recently bought a 2003 Mini Cooper S with 18,000 miles on it. The gear box has lately become hard to operate. The dealer (Patrick Mini in Schaumburg, IL first tried to lubricate the cables; it has helpful, but this "fix" did not last long. Patrick is now offering to replace the gearbox, but I have to pay for the labor, estimated at 10 hours @ $ 100 per hour or $ 1000. I am told the regional VP is the one who decides this kind of thing.
Does anyone have a related experience?
Ole
Old Apr 14, 2008 | 06:53 PM
zagadka's Avatar
zagadka
Hmmm...mine feels loose in 4th and stiff shifting into 2nd and 5th.
Depending on where you live I can put you in touch with my dude here in the northern burbs. Message me if you're interested.
Old Apr 16, 2008 | 08:52 AM
AutoXR53's Avatar
AutoXR53
If your shifter feels loose I would check your bushings. But as far as the stiff shifting my 03 hasn't had a problem but I run Royal Purple's equivalent to the stock fluid. As far as who decides you could be right I have no idea, but I would try the fluid change first and then if that doesn't fix it you may have to replace the trans. sorry
Old Apr 16, 2008 | 09:18 AM
golden_child's Avatar
golden_child
Coordinator :: Capital Area MINI Modders
Wasn't there a TSB on 03 shifter cables?
Old Apr 16, 2008 | 12:52 PM
zagadka's Avatar
zagadka
yeah i have a feeling its the bushings.
since i'm not the original owner, i'm sure 4th gear has seen plenty of down shifting use...
Old Apr 17, 2008 | 06:10 AM
AutoXR53's Avatar
AutoXR53
Yeah I see that happen a lot here at work, you should see some of the shifters. They are in gear and you can slop them around it looks like they could be in any gear... it's insane.
As for the bulletin I have access to alldata here at work and I looked it up. The only thing I could find
was a bulletin for the cables being stiff in low ambient temperatures. Basically moisture buildup and it freezing which could happen in any car to tell you the truth.
romansmini
Aug 25, 2015 11:57 AM
DiGiPiMP
Aug 24, 2015 11:04 AM
DWooderson
Aug 20, 2015 04:31 AM
minipopkart
Aug 13, 2015 05:22 AM
