AMVIV5 / A MINI Vacation In Vegas (2008) The forum for A Mini Vacation in Vegas, hosted by the Sin City MINI Club.
Alignment Shops?
Old Mar 20, 2008 | 07:53 AM
SimpsonGI's Avatar
SimpsonGI
Coordinator :: Emerald MINI Car Club
Alignment Shops?
Can some of you Las Vegas folks perhaps recommend an alignment shop? I'm having a set of H&R springs installed at AMVIV and I'm going to want to get it aligned before driving home.
Thanks!
Old Mar 20, 2008 | 08:30 AM
Speedwing's Avatar
Speedwing
OK .... Unless you have adjustable camber plates, I do not see how the alignment can change with a spring replacement (lower/higher ride height will change camber I know). Please correct me if I am wrong!! I see toe in and toe out adjustment on the front, no caster, and camber is fixed unless you have adjustable plates. I've heard -2 camber front and -1.5 rear, 0 toe in/out is optimum.
Old Mar 20, 2008 | 09:26 AM
SimpsonGI's Avatar
SimpsonGI
It can as the car is lowered which will affect the whole suspension system. Alta recommends a wheel alignment after installing replacement springs. They can get it close to where it should be when the springs are swapped out but I'd rather spend a little bit to make sure the alignment is correct then have to do it later and get a new set of tires.
Keet
SCCA Solo and ProSolo
Sep 20, 2015 01:02 PM
Keet
Sep 19, 2015 09:45 PM
Systemlord
Sep 19, 2015 02:57 PM
broncobuddha
Suspension
Sep 18, 2015 05:16 PM
Denly
Canada
Sep 15, 2015 12:55 PM
