AMVIV4 / A MINI Vacation In Vegas (2007) The forum for A Mini Vacation in Vegas, hosted by the Sin City MINI Club.
Webb Motorsports PULLEY PARTY at AMVIV!
Old Feb 12, 2007 | 12:59 PM
  #76
dragonflyer's Avatar
dragonflyer
Hey Randy. I'll will most likely be sharing that same space with you this year. I'm going to grab the same corner I did last year. That way if I loose my tent again I won't kill anyone The rest of you may no9t want to park under me just in case JK I'm coming prepared this year
So I think your good with taking up the other corner.
Something else that I'll talk to you about in PM
Old Feb 12, 2007 | 02:56 PM
  #77
Agro's Avatar
Agro
Coordinator :: Sin City MINI Club & AMVIV
All vendors will have pre-assigned spots and we would REALLY appreciate it if you set up in the location you're assigned.
That said, Randy, Mike and Waylen are all (currently) assigned to "Installers Corner" where you were last year.
Old Feb 13, 2007 | 01:05 PM
  #78
dragonflyer
Cool with me. I already talked to Mark about it so that was why I brought it up.
Old Feb 13, 2007 | 02:50 PM
  #79
Eric_Rowland's Avatar
Eric_Rowland
Or Agro will make you play Keno all weekend.
Old Feb 13, 2007 | 03:21 PM
  #80
Agro's Avatar
Agro
Not me. I would never tell anyone to play Keno. Casinos LOOOOVE Keno players. Worst odds in town.
But many of you will remember the SCMC Sergeant At Arms, Todd. You don't want to **** him off too bad.
Old Feb 13, 2007 | 09:11 PM
  #81
mini_dreams's Avatar
mini_dreams
Originally Posted by RandyBMC
Be sure to stop by for the tech talks each day as well - we will be doing several. Thursday will be suspension, considering most of the day is a suspension install sign up. Saturday will be engine with all of the pulley upgrades. Friday will be open line Friday with anything anyone wants to discuss! If you have never seen one, we discuss everything with the car apart for you to see - a very visual tech talk. For the engine talk, I have the entire motor in the air for the pulley install an go through the entire induction and exhaust loop, hitting the highlights specific to the MINI. Those that have seen a tech talk can shed light on the experience. Most people get a kick out of my description of the Cooper S's four strokes...
Randy
Randy... this will be my first time at AMVIV (not to mention a big MINI event) and this sounds pretty interesting... I'm not mechanical but would like to learn more about my car.
I've kinda thought I would stay away from mods because of the money, but now I'm getting intrigued. Can you briefly explain the benefits of a pulley and/or intake? I've had a vew people tell me that a cold air intake will make a big difference but don't know much about pulleys.
Also, my MINI is pretty new... does adding a pulley or intake void the warranty?
Looking forward to meeting you in Vegas.
Old Feb 14, 2007 | 09:09 AM
  #82
Steve_LV's Avatar
Steve_LV
Randy,
Will you have an exhaust for the S-cabrio?
Steve
Old Feb 14, 2007 | 06:20 PM
  #83
RandyBMC's Avatar
RandyBMC
Temporarily Banned
This is a clip from my FAQ over on www.webbmotorsports.com -
My thoughts on appropriate pulley reduction are based on a lot of time spent on the subject - including track testing with real-time data gathering of manifold inlet, supercharger outlet and water temps, long engineering discussions with Eaton (the manufacturer of our supercharger), and plenty of dyno testing.
We started developing the supercharger pulleys in the US before most all of the aftermarket, including the "factory" aftermarket - John Cooper Works. I started with a 10%, 12%, 15% and 18% reduction from stock. What we came up with after all that testing was that the 15% is the optimum reduction based on several factors. Remember that the goal of all of this is to have the highest DENSITY air parcel at the inlet port to the combustion chamber. Density is directly proportional to pressure and indirectly proportional to temperature, or D=p/t .
That makes the most significant performance factor the adiabatic efficiency rate of the Eaton supercharger at increased RPM. In short, it isn't great. The forte of the Roots type supercharger (which includes the Eaton) is high efficiency at low boost - giving rapid response without "lag". The faster you spin the rotors, the more you compress the air going through it - however, you are also increasing the heat (remember that from physics - anytime you compress you also heat). Some rotor designs minimize the effect of this, but the Roots does not. All of that means that while you are increasing pressure, at some point the heat you generate with additional compression will outweigh the pressure increase, and that point is with a 15% at about 5400RPM and higher. You also need to outweigh the fact that you are causing additional drag on the crank pulley by spinning at a higher resistance when you are forcing a higher parcel compression.
The other factors are more reliability based. The most significant of these is belt life. No matter which belt we try to use, they all fail with anything greater than a 15% reduction pulley on the track. I have three cars we have used on the street and track with higher reductions than 15% for data gathering, and even on the street it is a 50/50 on the belt failing. We have tried literally every belt on the market, and the issue is not corrected.
Also related to reliability, but much less of an issue, is the water pump speed. We didn't think this was an issue at first, until we started monitoring oil temp as well as coolant temp. On the track, we noticed elevated oil temps that we didn't see with 15% pulleys. It took a bit to figure this one out, but if the pump is cavitating, it will show first on oil temp. The reason behind it has to do with the volume of water and its movement through the entire head versus through the oil cooler. On the MINI, the oil is cooled with a water-oil exchanger. The water volume is great enough in the entire system that a small flow change does not effect coolant temp at the coolant temp sensor, but with the small volume in the oil cooler, the oil is not cooled as efficiently if the flow is decreased even a small amount, resulting in higher oil temps. This seems only to be an issue with the 19% reduction pulley at sustained high RPM.
I have personally installed over 800 15% reduction pulleys, and have not had a single issue with any of them. I have installed 4 pulleys greater than 15% reductions, and have had issues with all of them. Based on this, the preliminary testing we did, manufacturer discussions, and the fact that a few months after we came out with a 15% reduction recommendation John Cooper Works came out with a pulley on their supercharger that was within .03" of a 15% reduction, I can confidently say that the 15% reduction pulley is the best choice for not only performance, but reliability as well.
That covers most questions about the pulley - I offer a warranty with my installs that is the best in the business (of any aftermarket, not just the MINI aftermarket).
Hope that helps!
Randy
Old Feb 14, 2007 | 06:21 PM
  #84
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Originally Posted by Steve_LV
Randy,
Steve
Steve,
I can have a Milltek for the Cabrio... but I need to know beforehand so I can ship it out there (I'm driving the MINI out so it won't fit).
Randy
Old Feb 15, 2007 | 08:23 AM
  #85
Steve_LV's Avatar
Steve_LV
Steve,
Randy
Hi Randy,
I signed up over at your website for the 3:30 pm Saturday time slot.
Steve
Old Feb 15, 2007 | 04:27 PM
  #86
mini_dreams
Randy -- Thanks for all of the information. I'm not sure I got it all, but you definitely sound like the man for pulley installation. I'm impressed when someone goes through the kind of testing and research you do to make sure a product works.
I may wait this time but will drop by your booth.
Thanks!
Old Feb 16, 2007 | 08:28 PM
  #87
roggenmini's Avatar
roggenmini
Randy,
I would like to slip into the 3:30 on Friday for a SC Pulley if it is still open. And if you don't think my car will be too hot from the drive down from SLC. I am leaving Friday morning early. So there may be time for it to cool before 3:30. I will try and post to your site as well. I just reg'd so I am waiting for the admin email.
Thanks,
Ryan (roggenmini)
Old Feb 20, 2007 | 12:38 PM
  #88
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Got you guys in!
Steve,
Did you want the exhaut too? Right now, I just have you down for the pulley.
There is only one slot left
Once full, I am not going to be doing any late night installs . The last slot is Sunday morning at 8:00....
See you there!!
Randy
Old Feb 20, 2007 | 12:54 PM
  #89
Steve_LV's Avatar
Steve_LV
Got you guys in!
Steve,
Randy
Yep, I'd like the exhaust too.
Steve
Old Feb 20, 2007 | 03:29 PM
  #90
Agro's Avatar
Agro
Got you guys in!
See you there!!
Randy
I'll believe that when I see it!
Old Feb 20, 2007 | 03:31 PM
  #91
RandyBMC's Avatar
RandyBMC
Temporarily Banned
I'm bringing Vicky to keep me in line!
Randy
Old Feb 20, 2007 | 03:37 PM
  #92
Eric_Rowland
That didn't work last time.
Old Feb 20, 2007 | 04:20 PM
  #93
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Yeah, but we had the kids with us last time! It is just going to be the two of us this time (so she'll only have me to corral instead of the other four kids) .
Randy
Old Feb 20, 2007 | 08:09 PM
  #94
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Steve
Got it - see you there!!
Thanks,
Randy
Old Feb 21, 2007 | 12:36 PM
  #95
roggenmini's Avatar
roggenmini
Randy,
Are you going to have any extra Intakes with you? I am trying to re-do the budget so I can get one installed at the same time as the Pulley. If not when do I need to let you know if I am going to get it?
Thanks,
Ryan
Old Feb 21, 2007 | 09:02 PM
  #96
RandyBMC's Avatar
RandyBMC
Temporarily Banned
I hope to. I am finally shipping intakes, so I need to fill back orders. Once we get production running, it should be a week from start to finish on the SportBox. I plan to bring at least 10...
Hope that helps!
Randy
Old Feb 23, 2007 | 04:15 PM
  #97
RandyBMC's Avatar
RandyBMC
Temporarily Banned
All full! Feel free to start an alternate list - if there is a cancellation, I can fill them that way.
Even if you are not on the list, please stop by to check out our tech talks and new products!
Thanks,
Randy
Old Feb 23, 2007 | 05:55 PM
  #98
roggenmini's Avatar
roggenmini
Randy,
Go ahead and put me down for a Sport Box as well! It will be such a momentous moment!!!
Ryan (roggen/roggenmini)
Old Feb 23, 2007 | 06:53 PM
  #99
RandyBMC's Avatar
RandyBMC
Temporarily Banned
No problem - thanks!
Randy
Old Mar 5, 2007 | 08:13 AM
  #100
RandyBMC's Avatar
RandyBMC
Temporarily Banned
Due to unforseen circumstances, Joe can't make it to Vegas, which leaves an opening Saturday at 2:00! Act fast - this is the only opening.
See you soon!
Randy
