Alabama Motoring Society: BAMA and Rocket City The forum for the Alabama Motoring Society.
Visit the BAMA club site at www.bamamini.com
Visit the Rocket City MINI club site at www.rocketcitymini.com
Local Machine Shop
Old Feb 15, 2008 | 08:03 PM
Busta J's Avatar
Busta J
Local Machine Shop
I've got a new Mini coming, and will probably be buying some aftermarket wheels with 12mm lug holes. Since the new mini's use 14mm bolts, I'll either need to get the wheels drilled to 14mm, or use a 14 -> 12mm stud conversion kit.
So, anyone know of a reputable machine shop that could drill the holes without error? Seems like an easy job, but I'd rather pay a little extra for higher quality work.
Thanks!
Josh
Old Feb 16, 2008 | 09:19 AM
Louispup's Avatar
Louispup
Don't know, but I like your sig.
Old Feb 16, 2008 | 11:43 AM
bamatt's Avatar
bamatt
Another vote for not knowing but liking your siggy
Old Feb 16, 2008 | 11:53 AM
miniconcarne's Avatar
miniconcarne
Google search or phone book for wheel shops in the area. Call some, they may recomend a solution for you.
Old Feb 16, 2008 | 12:10 PM
morbius's Avatar
morbius
Dr. Morbius
Can not answer on where to go, but can answer that drilling is the wrong thing to do. Since the large bolt pattern will not in centered to the existing holes but more of an offset, the existing rims would have to milled/bored to the right size. It will not be cheap and the rims would have to be looked at carefully. If you could post a pic of the rim front and rear it would help.
A machine shop with a cnc horizontal mill can possibly do it and replicate it correctly to all rims, if they talk about a drill press, run !! Also note, no shop will take liability for altering a rim and may find that they will not touch it because of legal issues.
You would be much better off to find the right fit rims up front, safer, cheaper, and no warranty issues.
Hope that helps ....
Cheers,
Roberto
Old Feb 16, 2008 | 06:48 PM
Busta J's Avatar
Busta J
Thanks! I hate that mini went to a 14mm setup, but I guess my other option would be the stud conversion kit, or I've also heard that converting to the 12mm hub is not as complicated as it sounds.
Thanks for the help, and signature compliments!
battlehawk_mini
Mar 5, 2021 06:15 AM
UncDeo
Nov 4, 2019 04:08 AM
schwac2
Jun 14, 2016 04:06 PM
Southern Marylander
Sep 3, 2015 05:46 AM
Hippiehobbit267
Sep 1, 2015 06:13 PM
