WMW mods at MOTD 2011
Since the Dragon registration is opening, I thought I'd open up sign ups for mods or parts at MOTD. WMW will again have our full crew there to mod or service your MINI during MOTD. If you want something PLEASE SIGN UP, this will make scheduling to get everyone in much easier, and ensure I have the right parts for you.
Here are some of the things we've done in the past and will be doing again:
Pullies, Intakes, Exhausts, Sway Bars, Brakes, Cylinder heads, Superchargers, ECU quicktunes, Blow off valves, Shocks, Springs.
We will also be reprogramming and coding cars. We can change all the lock,window,light features, and more. Disable tire pressure monitoring, Disable seat belt warnings, change oil change indicator to be 7000miles, disable bulb warnings.
HOTCHKIS | DDM | CRAVEN | AKRAPOVIC | NM ENGINEERING | MEGAN | FORGE | IE | OS GIKEN | POWERFLEX and more
Yes we will be renting the go pro cameras again this year, we will also be including the Craven tow hook mount with the rental to use.
As for SS and other installs please email me directly with which short shifter you want, prices vary depending on which kit you want
Email me at: info@waymotorworks.com
More that we have to offer this year
WMW will also be doing everything for your MINI's computer.
We will be doing such things as:
Deactivate seat belt gongs for R55,56,57 MINIs
Deactivate Tire pressure monitoring on R50,R52,R53
Program NEW keys to your MINI
Activate Rear Fog lights, Alarms, Daytime running lights, reprogram lock features.
Airbag light diag, and resets
Clear CELs including 2096 faults
Update software in MINI control units
6spd conversion software update
And any other programming you can think of, just let me know and we'll see if we can do it.
Is it possible to re-calibrate the speedometer/odometer? I'm changing tire/wheel sizes (from 175/65/15 to 215/45/17) and according to a wheel calculator that I used that will put my speedo off almost 3% (and perhaps effect the odometer as well?). I do time speed distance rallies in this car sometimes so I'd like it to be accurate if possible.
Jerry from Savannah
Drove out to WMW today to have Way activate the OE alarm I installed a few weeks ago and while he was at it reset the oil service reminder to 7k miles instead of the OE 15k miles and activate the rear fog if I ever get the parts and install it. Great alternative to the dealer since Way is closer and cheaper.
Also got the quick tune with the raised rev limiter installed, car seems to be a bit smoother and maybe a bit more power but only have ~30 miles on it since it was installed this afternoon....and at some point I'll end up getting the dyno tune so the money spent on the quick tune applies to that.
