4th Annual MINIs on the Dragon (2006) Ready to take your turn trying to tame the Dragon? Learn all about what will likely be one of the largest MINI gatherings in 2006.
MINI RC and toys...
Old Jan 28, 2006 | 05:37 PM
  #51
KarenTKD's Avatar
KarenTKD
Originally Posted by thefuturequeenofnebraska
OH yea! (and I got him a RC to make into RCAgokart)
*sadly they are both Coopers tho... I couldnt find MCS RCs anywhere!
Try Big Lots. Right before Christmas, I got an EB/W MCS (just like my Giles; Chad would have to paint the roof black, tho) 1:9 RC. Check out the collector boards, too. I think someone out in Vegas mentioned his Big Lots had a ton, and he might be willing to help you obtain one.
If you want to see what it looks like, I've got a picture of it in my gallery.
Old Jan 28, 2006 | 08:10 PM
  #52
MiniManiac74's Avatar
MiniManiac74
Originally Posted by DrDiff
I have always wanted to see how my M03L would hold up against a M03!
You will get your chance. I have one with a wicked fast engine and upgraded suspension. The other is bone stock.
Old Jan 30, 2006 | 01:25 PM
  #53
Scavenger's Avatar
Scavenger
Cool, my first one was called the "Rock Buster"... it was a clone of Tamiya's Grasshopper. It didn't take me long to trash it and decide I wanted a true performance buggy - the RC10.
I've got aftermarket suspension, but the rest is stock. The tub chassis is in excellent condition too! I plan to charge it and give it a try soon.
That was my first real RC race car. I did so much to it. Losi Diff tube, MiCalister lowering kit, Hot Trick graphite chassis, Stealth tranny. HPI 2.0 truck tires...
My first RC car was a Tamiya Frog. Memmories!
Old Jan 30, 2006 | 04:38 PM
  #54
MSFITOY's Avatar
MSFITOY
I've still got my Tamiya Toyota Bruiser with 3sp tranny, shift on the fly
Old Jan 30, 2006 | 11:59 PM
  #55
MSFIT's Avatar
MSFIT
i'll bring my baby
Old Jan 31, 2006 | 04:38 AM
  #56
MSFITOY's Avatar
MSFITOY
Originally Posted by TheWrks
I'm Still thinking about it
3 months left to think about it
Old Jan 31, 2006 | 05:02 AM
  #57
IanF's Avatar
IanF
Nice! Does it still run? I knew a guy who had one "back in the day" (1984). They were expensive even back then - over $300 for the kit alone, if I remember right and then you needed the more expensive 3 channel radio.
So tempting to order on of those Tamiya Mini kits... To me, they've gotta be kits, rather than RTR. IMO, half the fun is putting it together!
Old Jan 31, 2006 | 05:27 AM
  #58
MSFITOY's Avatar
MSFITOY
It's been sitting for over 15 years. I've been meaning to strip it down and restore it back to top condition. The 3 speed gearbox is really trick...I made a gate for one of the two channel stick so it shifted just like a real tranny on the fly
On the other hand...I should've left this one in the box
http://cgi.ebay.com/TAMIYA-BRUISER-O...QQcmdZViewItem
http://cgi.ebay.com/Vintage-Tamiya-B...QQcmdZViewItem
Old Jan 31, 2006 | 08:15 AM
  #59
DrDiff's Avatar
DrDiff
Coordinator :: Northwest Indiana MINIacs
If you are going after a Tamiya M03 or M03L You will need ball bearings,
DTXC1547 Duratrax 5x11 bearing Quantity 12 or 6 packs
DTXC1523 Duratrax 5x8 bearing Quantity 2 or 1 pack.
And the newer ones (at least in shops) will have an electronic forward & Reverse speed Control
Old Feb 1, 2006 | 09:22 AM
  #60
Scavenger's Avatar
Scavenger
Over the weekend, I pulled out the RC10. Charged up the battery and gave it a test run around the basement. It still works! ...kinda. Problems are:
1. Reverse not working
2. Loose connection in the BEC (remember those?) causing intermittant power loss.
3. Wheelbase too long for MINI body!
Seems prettymuch decided, that if I want an RC MINI, I'm going to have to put the the $$$ for a whole new kit!! Darn! I'm not sure I want to do that right now....
Old Feb 2, 2006 | 07:52 AM
  #61
DrDiff's Avatar
DrDiff
burnt out resistor?
easy to solve but time consuming
well .......
Seems prettymuch decided, that if I want an RC MINI, I'm going to have to put the the $$$ for a whole new kit!! Darn! I'm not sure I want to do that right now.... [/quote]
$100 for the kit at tower and your choice Classic MINI or New MINI. You can use the servo and RX that you already have. If you get a newer kit they actually come with an electronic speed control with them! If you order through them I would specifically ask that they ship you a kit with an ESC.
Old Feb 2, 2006 | 06:34 PM
  #62
TheWrks's Avatar
TheWrks
Coordinator :: Michigan MINI Motor Club
Drifting R/C cars
Old Feb 2, 2006 | 06:42 PM
  #63
Zyamfier's Avatar
Zyamfier
Coordinator :: Cooper Owners of Rural Nebraska (CORN)
now that was cool
Old Feb 2, 2006 | 10:22 PM
  #64
Scavenger's Avatar
Scavenger
That was very cool!! To bad they didn't have a MINI
Old Feb 3, 2006 | 12:18 PM
  #65
DrDiff's Avatar
DrDiff
There is a Drift race class at Indy Slots South. 4wd open but uses a spec "Tire" It is not pvc because that is white but it is simmilar and black plastic tubing that fits over the rims. It is an open class but you rarely need more than a Chameleon or stock motor. The bodies don't tear up as badly as in the foam tire class but... They still tear up. You need 4wd to Drift.
Old Feb 3, 2006 | 12:24 PM
  #66
MSFITOY's Avatar
MSFITOY
PVC tires? Like in PVC hard white pipes? I've got the AWD so we'll give the sliding a shot
Old Feb 5, 2006 | 06:20 PM
  #67
DrDiff's Avatar
DrDiff
Yes PVC hard white pipes. But there is also a gray/black variety and that is what they use. Works well on Ozite. Also well on black top!
Old Apr 5, 2006 | 11:32 AM
  #68
jcmini's Avatar
jcmini
Cool here everyone talk about all those old cars. I work at a hobby shop right when the RC car thing started getting big in the lat 80’s. Tamiya was it back then. Later the RC10 was top notch.
My first one was the Tamiya Dune Buggy. All metal lead sled, water tight, very cool. Still have it but its bet to hell. Still have several of the old Kyoshos to
Going to bring my very custom RC MINI original to!! It’s only 1/12 scale but man does she fly
Old Apr 13, 2006 | 10:50 PM
  #69
dragonflyer's Avatar
dragonflyer
Hey Misfitoy,
Do you remember this from last year. I started a Mini Monster truck and showed this pic on the RC thread.
Well it's done and I'm bringing it to the dragon Feast your eyes.
Old Apr 14, 2006 | 05:04 AM
  #70
SheaJeff's Avatar
SheaJeff
You should have it jump a bunch of other R/C Mini's lined up.
(not that I'm offering mine!)
Old Apr 14, 2006 | 12:25 PM
  #71
dragonflyer
Ahh Come on man take one for the team. We'll put your car in the front of the line. Less chance of a colission
Dec 23, 2015 10:36 AM
Dashdog
Aug 10, 2015 06:17 AM
Aug 7, 2015 05:56 AM
Aug 7, 2015 05:55 AM
