Originally Posted by Learnincurve
(Post 4437332)
1. deactivate cold/hot checks on indicator, stop and reversing lights (Successful)
TIA |
The bulb check warns you if the bulb is out. It sends current to the bulb and expects a response, if not you get a bulb out warning. By defeating it you no longer get that warning. People who want flicker free LED lights deactivate. I'd rather have non LEDs and know when my bulbs are out.
(Post 4437332)
Hi,
I installed bimmercode and unlocked coding yesterday, hoping to: 4. If possible I would like to auto lower door mirror on reverse (I activated this in the code, but selecting reverse in the garage did not move the mirror. Later reverted the setting back to inactive). |
Originally Posted by peterpan101
(Post 4437983)
Make sure the mirror adjust switch is toward drivers side, that activates it. Toward passenger side won't work
Originally Posted by xentar
(Post 4438294)
in addition to that, your car should also have the power folding side mirrors.
Is there a way to enable fog lights with just the parking lights on?
My car is 2016 F56 S automatic if that matters. LED lights. |
Originally Posted by rockhouse66
(Post 4440335)
My car is 2016 F56 S automatic if that matters. LED lights. Yes, do a search, I documented it. https://www.northamericanmotoring.co...ml#post4330643 |
I just did the coding to see Videos in movement in my F56 JCW but in the USB I can only play the video files as music not video.
What I am doing wronf ?, let me know! |
I forgot to tell that the format of the Videos in the USB is MP4.
Please help!! |
Originally Posted by R53hyperblue
(Post 4444587)
Please help!! Go to Multimedia --> External devices --> select the USB symbol --> Additional media --> Video then you can select the directory where your video files are stored if needed. |
(Post 4444655)
did you try to do these steps?
Go to Multimedia --> External devices --> select the USB symbol --> Additional media --> Video then you can select the directory where your video files are stored if needed. What versión is ur Mini ? Thank you so much xentar |
(Post 4444657)
no only I went to the symbol of music and the USB, I tried to look something like u told me but I didnt find multimedia option (where is located)
What versión is ur Mini ? Thank you so much xentar Multimedia is one of the icons from the centre console like telephone, radio, navigation (if equip) , mini connected, etc.* |
(Post 4444659)
what mini do u have ? mine is a F56 JCW 2019 |
(Post 4444662)
ok let me look it again
what mini do u have ? mine is a F56 JCW 2019 I got a 2016 F56 MCS.. Since you have a newer version of the centre console, you may want to check your car's manual on how to play video via USB. |
(Post 4444666)
(Post 4444671)
but I dont think this information is in the manual because to see video we need to do coding =(
(Post 4444674)
The steps that I provided are from the manual. You don't need to do coding for the video playback to work. Video in motion is when you want to continue watching video when the car is moving. I think by default and for safety purposes, the video can only be displayed on the screen when the car is in Park (P) and not in R, N and D.
Originally Posted by ranger052
(Post 4433399)
were you able to figure it out? I have same issue lol |
Originally Posted by curlywurly
(Post 4445324)
Three of us now. On my Feb 2017 build F56 w/LED lights. Coded in expert with Bimmercode. Triple checked im following the simple lines in the first posts. Im going to set back to stock / no fogs and reassess
The coding I posted are for my Feb 2017 F56S. So, it’s not the build. |
Originally Posted by TVPostSound
(Post 4445328)
The coding I posted are for my Feb 2017 F56S. So, it’s not the build. Just updated bimmercode app (new push since i was last on 6 days ago) triple checked my settings for the left/right lights: MAPPING_BREMSL_2_L_OUTPUT AND the corresponding right side MAPPING_BREMSL_2_R_OUTPUT accessing both has the app taking me to a screen with the output choices. Radio buttons beside each to select Ive chosen nsl_l for the left output and nsl_r for the right output The fog lights do act as additional brake lights - but my LED main brake lights only light up the lower half circle: the 9 o clock to 3 o clock. No upper circle. Potential Variables/commonalities with others having 'half light' Maybe others can chime in - see if we can narrow it down I have the fog switch /fogs enabled/step not needed. In checking my settings for fog light active as a first step - i noted it was already on. Didnt perform that code/cycle Ive reconnected to the BDC EDU and changed the foglight output for brakes to OFF. I Still have the 'halfmoon' regular brake lights - so i'll keep digging.....i did find this translation of all outputs. trial and error time... sl_l (this is the side light choice) fra_h_l (turn signals?) bfd_l (brake force? sml_l (no idea? nsl_l (this is the rear fog light) |
For the couple of other chaps with only half the brake circle lighting up - thought id share my experiments to get back in business
Prob: only the bottom half of lights up/has light outputting when shifting to the fog lights output fooling around all done in the BDC ecu - and in expert mode So - top and bottom half circles seem to have outputs splint into two BREMSL_1_L_OUTPUT - this is in the LceLampMapping 3 item looks to be the bottom half of the LED circle only has two options. bl_l or off. same for the right hand side...... BREMSL_2_L_OUTPUT - this is in the LceLampMapping 4 item looks to control the TOP half of the LED circle. options for output: looks like i cannot switch light output to the fogs without losing the top. ive cycled thro all options. To get the full circle, and brake force - im chosing the bfd_l option. works for me for now.... YMMV. hope sharing my investigations helps those with the same whoops moment.... https://cimg4.ibsrv.net/gimg/www.nor...1f693084e1.png |
Has anyone figured out how to separate the brake and turn signal functions with the Union Jack tail lights? My car (2019 F57) has the lights from the factory, but as most know they don't function the same as they do in the UK/Europe, where the brake and turn signals lights are separated functions.
Anyone know how to disable the parking lights? (the ones housed in the fog light next to the DRL light)
Originally Posted by NBCGLX
(Post 4446927)
Most cars for the US operate the same way, wrt brake and indicator being the same light. |
(Post 4438294)
