F60 Oil Filter Housing Replacement- Looking for a How-To guide
I'm looking for any step by step information on how to replace an oil filter housing on a 2017 F60. Either in written form or video would be helpful. Any tips much appreciated. Thank you.
This is the F56 version from the post here: https://www.northamericanmotoring.co...s-done-it.html
Its the same on the engine side and about the same on that fabric pan side. You should have more room and the core support is a different set up
tps://static.nhtsa.gov/odi/tsbs/20...48281-9999.pdf
Oil change helps you on that part: https://www.northamericanmotoring.co...ge-on-gp3.html
For people 2020+ https://www.northamericanmotoring.co...il-change.html
This guy overseas did it on the F60MINI Countryman :
My condolences BTW, not a cheap part. Is there what FCP Euro calls an "OE" version of that part, where it's the same part but just bought directly from the manufacturer instead of via BMW?
I still can't access ECS Tuning since they block VPNs, so I can't check there.
Can you use our site off VPN or through a smart phone? I reported it to my data team and they said their are security measures in place to protect thus blocking some vpns.
Their is mahle which is the OEM but the mahle one originally fails. Most people go with the metal bremmen part version as an upgrade.
https://www.ecstuning.com/Search/Sit...h/11428585235/
