F60 Rear wheel arch replacement
Hello! Just got my 2019 F60 countryman s. We have to replace the rear wheel arch next to the passenger door. We have the replacement part, but need a video or instructions on doing this. Does anyone have info on this?
Thank you very much!
Kalena
Kalena
Hello
https://www.realoem.com/bmw/enUS/sho...diagId=51_4826
#3 and #4
Rear right https://www.ecstuning.com/Search/Sit...h/51777389364/
Rear right https://www.ecstuning.com/Search/Sit...h/51777391094/
#3 and #4
I have the replacement parts, but need detailed instructions. Not finding any videos for this. Din’t want to get the installation wrong. Thank you for the links. It does give me a good idea of what is needed.
Ok no problem, they just clip out and clip the new one in. I would get trim tools. https://www.ecstuning.com/b-schwaben...ieces/phr-05s/
Make sure the clips are lined up and snap into place, on the back you can see the clips are there for the main pieces, make sure the old ones are off the body and might need to get some pliers out as when you pull off the old arches those clips can break and stick. Two screw on each side upper and lower need installed behind the wheel liner. https://www.realoem.com/bmw/enUS/sho...diagId=51_5552 number 6 you can pull back a hair.
This pieces has outside clips that you will have to work around the edge to press in. I like to use a little rubber mallet or my hand to bump the clips to the body. Quick little bumps.
Make sure you unplug the side marker light and plug the new one in.
Its hard to find youtube and videos on these newer MINIs , that's why i am here to help.
Welcome!
davlad01
May 11, 2013 10:00 PM
carsncars
Dec 4, 2008 04:38 PM
R50/53 Cowling replacement how-to?
PixelPusher
Feb 13, 2007 01:57 PM
