2nd Gen Countryman (F60) Talk (2016-2024) Second Generation Countryman discussion. F60
F60 Brake replacement
Old Jan 14, 2024 | 09:11 AM
miniRogue1's Avatar
miniRogue1
Brake replacement
If my brake sensor is triggered for my rear brakes and i get the brakes replaced at an independent shop instead of the dealer. Will the warning go away or do i need to do something special to reset/remove it?
Old Jan 15, 2024 | 08:51 AM
2014 MC's Avatar
2014 MC
They should be replacing the sensor (gets worn through wire and opens the sensing circuit) that goes in the pad area and all should be good. Brake job is easy to do yourself...
Old Jan 15, 2024 | 08:54 AM
miniRogue1's Avatar
miniRogue1
yes sensor replacement will be part of the job. Just curious if there is any coding/something similar to be done after to remove the warning/notification from the screen or does a new sensor do the trick.
as for doing myself…no garage, no tools, no experience, temps in the teens and 20s.
Old Jan 15, 2024 | 08:59 AM
2014 MC's Avatar
2014 MC
I'm pretty sure there is nothing special that needs to be done if the wear sensor is tripped (and its not something else additional). Ya, no tools, location, cold weather sucks to do anything in.
Old Jan 15, 2024 | 09:00 AM
miniRogue1's Avatar
miniRogue1
thank you!
Old Jan 16, 2024 | 03:33 AM
eric.stewart's Avatar
eric.stewart
Veteran: Canadian Forces
+1 for what @2014 MC said.
Here2Go
Tires, Wheels, & Brakes
Jan 16, 2022 06:11 AM
SkipII
Dec 18, 2021 09:07 PM
Doubledee
Jun 27, 2018 05:17 AM
dominicminicoopers
Aug 27, 2003 08:22 AM
Grinder
Mar 30, 2003 08:44 AM
