F60 P2762
If you Google that code you will see that it indicates an issue with the torque converter clutch pressure solenoid control circuit. It's a component in your automatic transmission. You may wish to have (any) garage clear the code for you to see if it stays away, but given the symptoms you mentioned, it sounds like you will need to have your transmission diagnosed by an expert.
R50/53 2914 countryman P0300 code
suealber3
Oct 30, 2022 07:03 AM
ApexF60SE
May 19, 2021 01:34 PM
