2nd Gen Countryman (F60) Talk (2016-2024) Second Generation Countryman discussion. F60
F60 Front Skid Plate Protrusion
Old Apr 23, 2023 | 07:49 PM
dubs386's Avatar
dubs386
Out of curiosity, what is it that protrudes from the front skid plate, maybe a foot and a half behind the access panels for the oil filter/drain plug and directly under the front axle? It has a black, rectangular rubber splash guard on it. Almost looks like some sort of exhaust port. It's very noticeable in the below image from M7's product info sheet for their after market skid plate:
Source: https://www.m7tuning.com/f60-mini-cooper-skid-plate
I'm fairly certain this is a feature on all trims, but specifically - this is on my Countryman S ALL4.
I'll go ahead and put my dunce cap on and publicly shame myself: In the dim lighting under a car in an already dim garage, it looks an awful lot like a jack point... Yes, I'm an idiot and should have checked one of the many excellent posts I found on this site while panic-googling when the car stopped going up with additional pumps of the jack. The only saving grace to this blunder is that I think I caught my mistake fairly early... there's definitely some, erm, "plastic deformation," (see below pic) but there's no fluids, no CEL, no strange noises, and no immediately obvious emissions odors/leaks.. But I still want to know exactly how expensive a mistake this was (or will be, if I attempt to drive something that shouldn't be driven...).
Lesson learned the hard way... Thanks very much in advance.
Old Jun 21, 2023 | 08:11 AM
Yep, things hit that piece on the f56 also. Its more common then you think. Thanks for showing this on the F60.
https://www.northamericanmotoring.co...r-the-car.html
Here is the piece on the F60
Diagram: https://www.realoem.com/bmw/enUS/sho...diagId=11_5511
https://www.ecstuning.com/b-genuine-...o/11658605502/
Thats the acutal belly pan
https://www.ecstuning.com/b-genuine-...d/51757402947/
Old Jun 21, 2023 | 12:13 PM
bluonyx's Avatar
bluonyx
It's the air discharge duct for the turbo, all B48 engines have this underneath. Mine kind of hangs a little lower thru the belly pan.
MINI COOPER S TURBOCHARGER HEAT SHIELD AIR DUCT B46 B48
Old Jun 22, 2023 | 09:15 AM
Yep, seems like these are common for damage, the thing is this takes heat away from the turbo. You dont want to cut that off or restrict it.
Old Jun 22, 2023 | 02:43 PM
Mini-Titan's Avatar
Mini-Titan
I agree...that open rubber part protruding out into the under-car air-stream will help pull air through the structure above, which helps cooling. Physics is cool like that B-)
Old Jun 22, 2023 | 04:05 PM
2014 MC's Avatar
2014 MC
Bernoulli principle fan :-)
BendersMINI
Apr 14, 2015 06:51 AM
Z06C5R
32
Feb 17, 2009 08:05 PM
minicoaster27
Mar 26, 2008 05:44 PM
Jeremy1026
17
Aug 29, 2006 07:30 PM
bambam
33
Jun 7, 2005 04:31 PM
