2nd Gen Countryman (F60) Talk (2016-2024) Second Generation Countryman discussion. F60
F60 Rough Idle Problem
Old Mar 19, 2022 | 07:51 AM
DrewMini's Avatar
DrewMini
Rough Idle Problem
Looking for advice: I have a 2018 JCW F60 Countryman. I have an NM Engineering power module installed on the low setting. Recently the car runs fine but idles rough. I replaced the plugs with OEM, new air filter and added Techron fuel system cleaner. No improvement. Any ideas on what the issue might be?
Old Mar 20, 2022 | 12:34 PM
minor1000's Avatar
minor1000
is it worth it to take the power module out of the equation in case it’s having effect? I think it’s easy to do that.
Old Mar 20, 2022 | 02:20 PM
DrewMini's Avatar
DrewMini
Hi minor1000,
I already tried that. No change. One of my Bimmer coding friends said this is a relatively common problem that happens when you change fuel. I started putting in 89 octane (thanks to high gas prices) and now I think that was a bad idea. Switching back to 93 octane. He said that the solution is to "reset adaptation on DME" which is a code update. I need to explore that, but first I may run two full tanks of 93 and see if that clears up the problem.
Old Mar 20, 2022 | 03:03 PM
minor1000's Avatar
minor1000
I hope you post back when it’s fixed. i’m really curious to know. i have a 2019 ALL4 S, not a JCW, but with an official JCW tuning kit, fwiw, but anyway, i recently ran 2 tanks of 89. one by accident and one on purpose. i never heard any pinging and the car an great. i assumed that it did all of the timing adjustments on-the-fly, so it will be interesting to see if a reset fixes it if the gas doesn’t. it would be nice to see real-time ignition timing while driving just to know what’s going on.
ER9240
May 24, 2021 04:04 PM
geoangia
Sep 15, 2018 07:01 PM
Hizapitt
Sep 21, 2016 09:20 PM
dube53
Jun 7, 2015 02:23 AM
roverlandpark
Apr 21, 2015 03:56 PM
