2nd Gen Countryman (F60) Talk (2016-2024) Second Generation Countryman discussion. F60
F60 no-start and CID dims, but then starts
Old Jul 13, 2021 | 12:54 PM
minor1000's Avatar
minor1000
2019 MINI Cooper S Countryman ALL4
This car normally starts instantaneously, but yesterday when I got in, the middle instrument display (CID) lit up, but when I toggled the start toggle, the CID dimmed and no-start (but radio was still playing). So strange, I thought I was doing something wrong (maybe I was?). Anyway, I did it a couple more times with same behavior. Then I waited a minute and tried again and it started normallly.
Is this something common? I searched around and found threads about dim or flickering displays, but nothing related to no-start at the same time.
thx
Old Jul 14, 2021 | 04:33 AM
eric.stewart's Avatar
eric.stewart
Veteran: Canadian Forces
I'd bet on the battery being defective, but best to bring it in to the dealership as it's still likely under warranty if you're driving a 2019. They will likely check the charging circuit at the same time since if the battery doesn't have a full charge it's possible that the alternator isn't charging it.
Old Jul 14, 2021 | 01:05 PM
mikey_t's Avatar
mikey_t
I'll second that thought about the battery. The lifespan on MINI batteries has always seemed to be a bit on the short side and once they start acting up, numerous problems appear.
Old Jul 15, 2021 | 03:24 AM
Mini-Titan's Avatar
Mini-Titan
Battery. Or, loose battery connection. VERY common in many of the more modern vehicles. Honda Accord (2014) did that same thing for my daughter a few days ago...and that isn't as modern as the 2019 Mini.
Old Jul 22, 2021 | 12:03 PM
minor1000's Avatar
minor1000
I have an 8-speed automatic. When I drive in sport-mode(all the time), I have to "restrain" my self from pushing the shift forward going from 2nd to 3rd. I realized that, that was a normal shift point in my manual trans, from 2nd to 3rd gear, forward and to the right. But obviously, in my CMS I end up down-shifting if I push the shifter forward (ouch). Muscle memory. Only mentioning that because all my cars don't require pressing the brake down to start. I think I just spaced out and wasn't pressing the brake down when I tried to start the car. Just kind of mindless... :-)
If it turns out to be a car problem, I will report back, but I'm pretty sure this was user-error. No problems so far...
texasvwnut
Sep 15, 2019 05:06 PM
ewoj
Jul 5, 2019 03:08 PM
victoryrider
May 4, 2019 05:25 PM
brettno1
26
Oct 27, 2010 11:50 AM
