2nd Gen Countryman (F60) Talk (2016-2024) Second Generation Countryman discussion. F60
F60 Adding drivers assist
Old Oct 29, 2017 | 07:59 PM
Jwanck11's Avatar
Jwanck11
Apparently the assisted cruise uses a camera and I think my JCW has the forward facing camera needed.
I will be looking into the parts and coding to see if the mod can be done and if it can be done under 1K.
I added this to my F-150 and it was far cheaper for me to add...
Old Oct 30, 2017 | 06:54 AM
MrFunk's Avatar
MrFunk
I'd be shocked it if only uses a front facing camera. Typically it's radar as the fundamental technology.
Old Oct 30, 2017 | 08:00 AM
Jwanck11's Avatar
Jwanck11
I agree. My truck is radar-based technology. In the MINI manual however, it discusses only a camera. I am going through the service manual though to cross-reference and hopefully learn the parts needed.
Coding will be a completely different investigation... but not worth looking into until I know the parts situation.
Old Oct 30, 2017 | 08:54 AM
MrFunk's Avatar
MrFunk
I'm sure it's more than just the camera. I've never seen a system not with radar or laser or something else. You could ask a tech at Mini or even a BMW tech - I'm sure it's the same as the X1 system or any other BMW adaptive cruise system for that matter.
Old Oct 30, 2017 | 04:08 PM
MIminiclubman's Avatar
MIminiclubman
Subaru eyesight is the only one I know of that is camera only system. It uses 2 cameras so it can calculate depth just like our brains.
Old Nov 2, 2017 | 03:47 PM
Jwanck11's Avatar
Jwanck11
Read through the entire service manual and there are no module specifications/ install instructions. I did find a wiring diagram that does not list any sensor hardware, but did connect to the camera in front of the mirror.
I know I have the instrument cluster as it has the cruise light to be enabled...
Still looking.
Old Nov 18, 2017 | 04:17 PM
Jwanck11's Avatar
Jwanck11
I have found out the system is camera based. And, I have the camera (which sits just underneath the mirror). I do need a new component in the steering wheel. When I pop that off, I will see if I have the harness/ plugs to enable the system. After that, it will be a matter of finding a VIN of a MCC with Driver's Assist enabled and getting their asbuilt data. Progress.
Old Nov 18, 2017 | 07:14 PM
MrFunk's Avatar
MrFunk
Wow - very surprised it's camera only. Is it dual cameras for depth perception?
Old Nov 18, 2017 | 08:44 PM
rkw's Avatar
rkw
Did you find a used camera? New parts alone are well beyond your goal of staying under $1K.
http://www.realoem.com/bmw/enUS/part..._S&mg=66&sg=30
https://www.ecstuning.com/b-genuine-...a/66516822683/
https://www.ecstuning.com/b-genuine-...516992830~oem/
You might also need a new windshield.
