R60 Driver window switches not working
Old Mar 21, 2021 | 12:20 PM
bkurtz's Avatar
bkurtz
I have a 2013 Countryman S All4 and the drivers window switches and mirror control work off and on. I have gone through all the fuses and they are all good. The only thing I notice with it is that the right turn signal when you press it up and it gives you 3 blinks will stop working when the window control panel stops working. When it comes back on then the right 3 blinker works. Going full blinker to the right always works.
So I pulled the switch out of the door and it appears undamaged. The connector has a brown wire, orange and yellow wire, and a white and brown wire. Brown shows no power. Orange and yellow is getting 12 volts. White and Brown wire shows 3 volts and when i hit it with the reader the right blinker starts blinking. The next thing I was going to do was replace the window switch panel and see if that fixes things but the connection with the blinker makes me think that it wont fix things.
Any ideas or insight on this? Anyone else have this problem?
Old Mar 21, 2021 | 12:23 PM
bkurtz's Avatar
bkurtz
I think i put this in the wrong forum. Can someone move it to the repair section?
Old Mar 22, 2021 | 08:03 AM
bkurtz's Avatar
bkurtz
Not sure how to delete this. I copied it over to the repair section.
Old Nov 2, 2024 | 11:38 PM
Sugaldem's Avatar
Sugaldem
Please help man I have the same problem a
I have the exact same problem dude. Can’t fix it? Whats did you do?
Old Jan 24, 2025 | 09:46 AM
ScottS's Avatar
ScottS
Help
Did you find a solution?
Mr. Incredible
Jun 6, 2024 03:01 PM
painless_reck
Oct 8, 2022 11:35 AM
kpl
Aug 1, 2015 10:40 PM
Crimson Nape Racing
Jan 25, 2013 07:07 AM
Darren89
Electrical
Apr 4, 2012 03:06 PM
