R60 Intermittant ABS fault light
Old Jan 26, 2016 | 12:59 PM
contrail's Avatar
contrail
TL/DR: It was the low fluid sensor on the brake fluid reservoir.
2012 countryman with 60000 miles, about every 30 minutes of driving I would get 4 lights, the center exclamation point plus abs, traction and brake. A Google search led to a bad wheel pickup sensor seeming to be the most likely culprit. My tires needed rotating so I removed and cleaned all 4 sensors, they were dirty but no change to fault. So I was going to hook up an old ScanGauge to see if I could get a code but while looking at the code list some where around code # 2375 there was a low fluid code.
Added about 1/4 inch of DOT 4 to bring the level up the bottom of the screen in the brake fluid reservoir, another job well done.
Old Jan 26, 2016 | 01:57 PM
How was it low. Did you have a leak or bleed the brakes.
Old Jan 27, 2016 | 01:48 PM
contrail's Avatar
contrail
I'm going with evaporation and lack of preventative maintenance. I never thought to check the level, out of sight out of mind.
Old Jan 27, 2016 | 02:07 PM
Yea, should not have been low unless cap left undone or a bad job on the brake bleed and did not fill it back up by the previous owner or MINI dealership
Old Jul 12, 2016 | 09:45 PM
sull1102's Avatar
sull1102
THANK YOU! Just found this after dealing with flashing ABS and ! lights for two weeks.
daonlyillwiz
R60/R61 Stock Problems/Issues
44
Jul 18, 2023 06:06 AM
pppdxx
May 28, 2023 09:17 AM
KilmerPT
Feb 29, 2016 07:57 AM
kxmini
Jan 3, 2016 02:49 PM
wrnchhd
Dec 29, 2015 11:56 AM
