R60 Mr Kustom puddle light issue
Old Jan 20, 2015 | 04:58 PM
marbee40's Avatar
marbee40
The wife ordered a set of Mr. Kustom puddle lights with the USMC logo. I had already installed the "Mini" puddle lights into the factory light housing and she wants them moved to the rear doors.
The Mr. Kustom lights are NOT for the factory housing (plug-n-play).
The Mr. Kustom puddle lights require drilling a hole in the bottom of the door panel and splicing into the factory wiring. Not a big deal except her R60 has really deep door panel pockets (2013 R60 S AWD). The new puddle lights are approximately 2" long. The clearance between the bottom of the pocket and the bottom of the panel is only about 1".
Mr. Kustom recommends just putting them in the bottom of the door itself which requires drilling into the metal and doing a good silicone seal. Again, not the end of the world. My only problem is I can't figure out how to remove the damn door panel. The one you-tube video I found is for an older R60 with a different door panel.
I was able to pop the bottom plug/clips and about 1/3 of the way up either side of the door panel. Feels like something more solid beyond that. Yes, I pulled the armrest screw and the two bolts behind that. Any more secrets? I can't find any way to pull the door release handle. Most cars have a screw hidden. I'll take any tips!!!
If you need a pic of my door, let me know and I'll attach when I get home.
Thanks,
Jim in AK
Old Jan 21, 2015 | 10:09 AM
DWooderson's Avatar
DWooderson
Pics of the puddle light housings (both the Mini and the Mr. Kustom) would be helpful.
So there is no way to transplant the internals of Mr. Kustom light into the factory light housing?
Old Jan 21, 2015 | 10:46 AM
marbee40's Avatar
marbee40
I'll take detailed pix of both housings tonight. I might be able to switch out the USMC logo with the Mini logo and use the factory housing. Thanks.
Teh
Jun 13, 2018 02:59 PM
Colt45Magnus
Aug 12, 2015 06:43 AM
truedrew
R60/R61 Stock Problems/Issues
Aug 10, 2015 10:39 AM
quality_sound
Aug 7, 2015 09:36 AM
kwijmbo
Aug 5, 2015 09:00 PM
